Question about LeapFrog Clickstart My First Computer
Leapfrog my first computer and installation instructions
What does error 2046 mean, on my daughter's leappad2, creativity gallery section?
"I had the same problem. It is not a problem with leapfrog connect but with Adobe flash. First clear the cache and cookies in all browsers installed on your computer. Then go to the link on this website and untick the instructed box. >> https://forums.adobe.com/thread/1007636 https://get.adobe.com/flashplayer/ < and install flash
Aug 07, 2014 | LeapFrog LeapPad2 Explorer - Pink
Factory reset of leappad ultra
Download and install Leapfrog connect. If it doesn't download, there's an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Sep 12, 2013 | Toys
I have a LeapFrog My Pal Violet (and Scout). The have been personalized with my child's name and favorite "things". My question is: How do I reset or clear this personalized information...
Here you are. It took a while to find the instructions!
In addition, if you would like to delete the data on your device prior to recycling, open the LeapFrog Connect program, sync your device via USB to your computer, click on the product you would like to reset from the "My Products" screen, then under "Settings," select "Reset". If you have not downloaded LeapFrog Connect, please follow these instructions to do so.
eWaste
Aug 26, 2011 | LeapFrog My Pal Violet
Hi. Our son's Leapster Explorer is good, but we are unable to connect it to the website so we can download demos and check his progress. We follow the instructions on the Cd rom and internet but it...
Try to uninstall and re-install the LeapFrog Connect. Make sure you got the latest software form Leapfrog Website instead of install it from the CD supplied from the original box.
Jun 19, 2011 | Leapster 2
Hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
(Make sure your toy is powered on.)
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
Jul 02, 2010 | LeapFrog Tag Reading System
Have lost the instruction booklet for leapfrog my first computer
Hi!
You'll find the parent guide here;
http://www.leapfrog.com/etc/medialib/leapfrog/clickstart/cs_clickstart.Par.0.File.tmp/ClickStartWebPG.pdf
If the link does not open, go to www.leapfrog.com - click 3-5 years, you will find clickstart first computer in line 4.. - click the photo - scroll down under the large image to find the parent guide.
Good luck! :)
Cathy
Oct 21, 2009 | LeapFrog Clickstart My First Computer
Need manual for leapfrog clickstart
I did a google search -leapfrog my first computer and installation instructions and found it online....I have it as an pdf if you want me to send it to you...kellyjean@optimum.net ....good luck....
Jan 04, 2009 | LeapFrog Clickstart My First Computer Pink...
Computer will not download the connect cd
Question   My computer meets all the minimum system requirements but when I try to download the LeapFrog Connect Application, I receive the error message "Your computer must meet minimum required System Configuration" trnsp.gif   Answer   Please make sure your monitor resolution is set at 1024 X 768 pixels or higher and then try to download the application again.
Dec 24, 2008 | LeapFrog Tag Reading System w/ Bundle
LeapFrog Clickstart My First Computer Logo
241 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
thegtw
relojmesa
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
