Back to:
Tags:
Motorola RAZR V3xx Cellular Phone
Motorzr v8 Bluetooth problem
posted by tzvia on Jun 15, 2008
Bluetooth turns itself off after 3 minutes. Also does not automatically bond to motorola car kit. Have to rebond everytime
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 28, 2008
Thanks for Trying (70)
jerryg50
Rank:Wiz Wiz
Rating: 84%, 583 votes
The Bluetooth Transmitter/Reciever in the phone is probably defective. You can verify this by testing it with another Bluetooth device. If it fails with another device, then you know for sure that the phone has a fault.
The fix is to change the circuit board that has the Bluetooth processing. This fix will be expensive in relation to changing the phone if the phone is out of warranty.
Jerry G.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Motorzr v8 Bluetooth problem:
I don't want to Accept this solution
Solution #2
posted on Jul 20, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have another problem... My bluetooth detects other cellphones but no other cellphone detects my device... I t was working properly before but after some time it started doing this...
Thank You!
Can you Help with these Cellular Phones problems?
my motorola razor V3xx phone will not turn on. i turned...
Have the same problem. My phone lights for one sec only...
My phone wont allow me to open any text messages.  It...
i forgot my phone unlock code now when i switch it on it...
i need how work in tx an rx
Loading problems.
Repair Service
Find Cellular Phone Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
