Question about EuroTech Washing Machines
Dryer part, smells burnt and is extremely loud
  • 31 Answers
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Posted on Nov 07, 2010
3 Suggested Answers
SOURCE: burnt smell in dryer
Eliminate the dryer sheets and use liquid fabric softener. The burnt smell is GONE!!
Posted on Nov 27, 2007
heatman101
  • 43501 Answers
SOURCE: Dryer is making a loud high pitched noise and
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Apr 23, 2010
My dryer has burnt smell just buzzes but doesn't
Check the motor, it's sticking or already burned out
Mar 26, 2013 | Dryers
Dryer is making a loud high pitched noise and clothes are smelling like burnt rubber.
heatman101
Apr 22, 2010 | Maytag Performa PAV2200
Thumping noise (similar to shoes drying) and burnt smell
that one needs a serviceman to look at it too many variables as to cause
Jan 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Kenmore gas dryer made a loud buzzing sound and didn't start. I smelled burnt rubber smell. Dryer is totally unresponsive now. Breaker is ok, power is on.
Sounds like the belt has burned and broken. There is a switch on the tensioner that will not let the motor run if the belt breaks.
Dec 28, 2009 | Kenmore Dryers
Heard a loud pop...saw a bright flash...burnt smelled and dryer stopped working. Circuit breaker will not re-set.
You may have a wire that has come loose of it's restraints and is rubbing on the drum as it turns. This would cause the wire's insulation to wear off, and if it's an electric dryer, you're dealing with 220volt wiring. The spark and burning smell is similar to arc welding.
You'll need to open the dryer up and find the damaged wire and reinsulate it with electrical tape or heat-shrink wrap.
It should be easily visible ...look for the burnt,blackened marks..
Nov 01, 2009 | Frigidaire Dryers
My vacuum is loud and dies
your impeller is broken that make motor work harder and shut off
Oct 14, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Dryer was running with full load of clothes. Heard a loud pop twice, ran back to the laundry room and smelled like something burning. Turned dryer off, and now it won't start back. Also, the very top of...
Well it sounds like a sound I have heard... forgetting that I had a cigarette lighter in my pocket and having it explode from the heat in the dryer. But you say you heard two loud pops?
Once everything cools down, check again and report back... does the dryer not turn on at all? Does the light come on when you open the door? Does it buzz when you push the start button? Stuff like that.
Jul 27, 2009 | GE DBXR463EDWW Electric Dryer
Burnt smell in dryer
Open the service panel and check that the heating element is clear from any lint on it. Be awre you should unplug the power cable before touching the heating element. Good luck!
Sep 01, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Extreme heat, electrical smell
there could be lint on the heater also. clean if ve t-statso. you could also have a defecti
Feb 18, 2007 | Kenmore 84152 Electric Dryer
Washing Machines Logo
1,780 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
