Question about Bugaboo Cameleon Jogger
The Chassis part is loose. - Bugaboo Cameleon Jogger
  • maggiem4202 Nov 07, 2010
    The chassis is loose- in its locked positions it moves back and forth slightly, making it difficult to maneuver. I spoke to Bugaboo and they said that the only solution is to replace the whole piece ($300). It seems like it could be much simpler- like tightening a screw. Any suggestions?
    President:
  • 1,194 Answers
Thanks for using Fixya,
You can buy the part that is loose from this link. All the replacement parts that are avalable are listed there.
Good luck and have a nice day.
Posted on Nov 08, 2010
Dash indicators intermittent
Hi there
Either loose connection under dash or bad connection on earth on battery or chassis or loose term on alt/ engine /chassis etc
Feb 12, 2015 | 2000 Dodge Caravan
I have a 1998 Ford F-150, it has some kind of bumper mounted inside the frame near the front wheels. It's rusted and broke loose, what does it do and what's it for.
IT is a part of the chassis frame and is required for chassis strength and rigidity . If the rust is bad enough I would consider a replacement chassis from the wreckers as welding in parts will do more damage than good.
Feb 19, 2014 | Cars & Trucks
No video. audio comes through crystal clear. model #vs6140
A very common problem in older Mitsubishi sets is bad solder connections develop.
If bumping or jarring brings back picture you are going to have to get the entire chassis loose----it involves getting the chassis unbolted from cabinet, releasing some bundled wires and lifting chassis up so bottom is facing rear of set.
Then you take a good look in power supply and other areas for any "ringed" connections: connections that are cracked loose and not soldered solidly.
The hard part is getting the chassis loose; usually in this case I find four or more loose, or poor connections.
What happens is from age the board expands and contracts and some parts that produce more heat crack/break loose solder connections.
Let me know if you have questions.
Steve
Feb 29, 2012 | Mitsubishi VS-6041 60" Rear Projection...
I have a bugaboo cameleon 1st generation that has a fault. If i was to buy a new 2nd edition chassis would my carrycot still fix on to this chassis.
I have a second hand chameleon and it feels like the frame is a little loose. Is there any way that you could tighten the frame up?
May 10, 2011 | Bugaboo 'Cameleon' Stroller
My chassis is really loose.
You can call the support number at 1-800-951-4113. they should be able to assist you on how to tighten this.
Thank you.
There website is www.maxi-cosi.com
May 02, 2010 | Maxi-Cosi Loola Oxygen Umbrella Stroller
I need a new chassis as the handle bar wont go down
You can purchase a new handle from the suppliers or the retailier where you purchased the pram as this is much cheaper.
Hope this helps.
Mar 09, 2010 | Quinny Buzz Jogger
Capacitor locations
yes all wires need to be removed that run from the metal encased chassis the four boards that have bad caps are all located in that metal encased chassis. The FMT, DM, Singal and Power PCBs
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA Rear Projection TV P46770CK spark beneath chassis when power applied
It sounds to me that you may have a cold solder joint ( loose connection on the board ). I suggest you remove the board ( or seek professional assistance ) and solder any loose connections that you may find. That may correct the problem. Good Luck.
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Feb 17, 2008 | Televison & Video
No sound
reconnect all the cords in their respective jacks...ter will be some loose connection
Jan 02, 2008 | Loewe Aconda ACO9303 30" TV
Bugaboo Cameleon Jogger Logo
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
