Question about Brother MFC495CW
I placed a picture over the scanner glass and tried to scan it by pressing the scan key, but nothing happened Do I have to change any settings on my computer or brother machine? Please let me know...Thanks so much! Connie
  • connienorman Nov 10, 2010
    HI, I unplugged all the cables and did what you said, but it still doesn't scan. It goes through the process now and you think it's working but it doesn't. So, I'm assuming it may be an internal error like you said and that I may have to contact my dealer. Thanks so much!!!
    Guru:
  • 452 Answers
You do not change any setting on your computer and on your machine: the machine work as a scanner, if you click the scan Botton, you should go to scan utility on your computer and click the scan command to receive the numeric format of the original image placed on the glass, if you need help about '' how do you scan a documemt '' : 1) click the start botton 2) go to control panel 3) click twice on the scanner and photo 4) the assistant will guide you to scan your photo. if my solution helped you don't forget to vote.
Posted on Nov 07, 2010
  • 1 more comment
  • connienorman Nov 08, 2010
    When I press the scan button on the brother machine it just beeps and check connection shows up in the display. Everything is connected because I can print and send and receive faxes okay. I don't know what else to try
  • polytek Nov 08, 2010
    check connection can be an error of fax line, power off the machine, unplug usb cabble, power cable, phone line, wait for 10 mn, plug only the power cable, power the machine and press the scan button, if the message was not displayed plug in the others cable, if the message still i think it is an internal error, you should call your dealer.
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
I am trying to scan slides with Epson Perfection V500 Photo...I placed the slides in properly and press the scan button on the scanner. It scans the row of slides as they appear on the scanner bed. But...
You have to have the plastic slide holder (positioner) placed perfectly. Look at the "A" and "C" tabs on the plastic holder. If they don't position your slides over the center of the glass, you are using the wrong tab! Slides have to be back-lit, which is what the top cover does. It doesn't light up the sides of the scanner glass, only the middle.
Feb 04, 2011 | Epson Perfection™ V500 Flatbed Scanner
How do I scan a picture from the HP J4680 to computer
This is the step on how to scan docs using HP J4680:
    1. Press the "Power" button on the HP J4680 and lift the top cover. Place the document to be scanned on the scanner glass. Be sure the document is face down and properly aligned with the top, left-hand corner of the glass.
    2. Use the arrow keys on the control panel of the HP J4680 to select the "Scan" feature. Press "OK" to continue. Then Press the right arrow to select the scan feature. Press the "Start" button to begin the scan.
Dec 13, 2010 | HP J4680 Office Jet All-In-One Printer
Every time I scan lines appears either on document or pictures. I tried cleaning the glass but nothing happens.
Clean the **** glass with alcohol. The **** glass is the little glass that paper is scanned over when using a automatic document feeder.
Jun 18, 2010 | HP 5590 ScanJet Flatbed Scanner
My Dell copier model# A920 will not copy manually
If you want to scan you will need to connect the device to a computer. For copying, place a document to be copied on the flatbed scanner and press the color or black button (as appropriate).
Jun 02, 2009 | Dell A920 InkJet Printer
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
Scanning
Scanning Photos With the Control Panel Scan menu, you can scan photos to a file, application, or memory card.
Scan to File 1 Place a photo or photos face down on the scanner glass.
2 Press Scan to display the Scan menu.
3 Press �� or �� to select Photo.
4 Press �� until Scan To is selected.
5 Press �� or �� to select File.
6 Press Start.
The document is scanned and saved based on the Kodak AiO Home Center scan picture settings.
You can change the folder where you want these saved. Just go to tools in your printer window.
Hope this helps- Happy scanning!
Jan 29, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Scanning
hmmm...did you try this from the HP print manager on your computer?
that will help with deciding if it's a scanner issue, or maybe more like firmware.
www.hp.com
has that print manager.
Jun 01, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Brother MFC495CW Logo
300 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
