Question about KitchenAid 31 in. KGCS105 Gas Cooktop
RE my KitchenAid Gas 4 burner stove top Model kgct365x All of the sudden all four four burners stopped sparking. I'm guessing this is the spark module, Harper-Wyman 6540 (120VAC, 60 Hz, 8mA) Any other thoughts? The closest replacement I can find is Part# 6540S0001. Will that work? Thanks
    Director Badge:
    Uploaded 100 video answers.
  • KitchenAid Master
  • 488 Answers
In this video You can see how to replace any component on kitchenaid cooktops! I hope it helps. Thanks! How To Repair Whirlpool KitchenAid Stove Cooktop HD 1080
Posted on Jan 24, 2015
fridgetech
  • 473 Answers
SOURCE: electronic igniter stopped working
Sounds like the spark module has gone bad. Need to make sure you have voltage to the cooktop first.
Posted on Nov 15, 2007
  • 125 Answers
SOURCE: burner caps
Call a local independent whirlpool dealer. they can order the parts from a supplier, and most do not charge sipping as sears a.k.a. A&E will. And they will usually be less expensive too.
Posted on Aug 24, 2008
SOURCE: One burner igniter fails to spark after getting wet
Each burner has its own switch to direct current to the igniter. It appears that one of the four switches burned or shorted out, while the other three survived the flood. These switches are replaceable, so that's how I'll fix the problem.
Posted on Jun 27, 2009
  • 10865 Answers
SOURCE: Hi, I need to find
Hello. Generally, the best local source for LP gas valves is your LP gas provider, give them a call. Also, there are several other sources including http://www.kitchenstuff.com/items.asp?Cc=HS1077, and local plumbing supply houses. J.
Posted on Jul 09, 2010
SOURCE: I have model # KGCT365X KitchenAid gas cooktop and
All four of mine did this.I glued it with a good quality super glue (don't get any inside or it won't fit back on)
Then I wrapped it many, many times with fishing string.Glue the end of the string after you cut it.Make sure that it holds.Then using alot of the super glue,spread/smear it all over the string.Its almost like fiberglass.Let it dry up real good over night.The first one I did almost 6 years ago and still holding.It's a lot guicker and easier then it sounds.
Posted on Aug 10, 2010
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
The ignitor will not stop sparking.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 23, 2010 | Jenn-Air 30 in. JGD8430A Gas Cooktop
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Burner caps
Aug 24, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Electronic igniter stopped working
I recorded video to let u see how its done. Problem Was : non of the burners would ignite (no sparks when knob is turned on). First sigh of bad spark module, but I got spark switches(they harness) as well just in case - One of the spark switches was bad - Check my video how I replaced them. Non of the screws was coming out.
Nov 15, 2007 | KitchenAid 31 in. KGCS105 Gas Cooktop
KitchenAid 31 in. KGCS105 Gas Cooktop Logo
436 people viewed this question
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
