Hello ! My philips 20ht3303 hotel TV doesn't work with 3,19,7,5,3,mute code to enter in menu option . Is there any else code or my tv blocked after i had been use it ? It worked a few times , but now doesn't works anymore . Thanx !
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
ctf1800
  • 4402 Answers
SOURCE: PHILIPS HDTV 30PW8420/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Posted on Dec 06, 2007
  • 346 Answers
SOURCE: I have a Innovage Jumbo Universal Remote
is it for the tv or the vcr ?
Posted on Dec 26, 2007
SOURCE: Remote Codes
i lost the codes of my remote and now it's malfunctioning.. the brand is CHUNGHOP RM-88E..the Brand of my tv is Goldstar.. can you help me with this or can you just give the codes?
Posted on May 19, 2008
  • 362 Answers
SOURCE: remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Posted on Jan 27, 2009
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
Cant unlock tv because the code 319753 mute is no longer working
Hello
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Aug 01, 2011 | Philips 20PT6441 20" TV
I need the code that will tske my samsung 40" out off hotel mode
hello,
To switch off hotel ode on samsung, enter:
1. On standby press info-menu-mute-power or,
2. press mute-1-8-2
After service mode appear, Choose option block,
Fine Hotel mode, change to off.
If in option block you can't fine it, try open other block.
Good luck.
Apr 16, 2011 | Televison & Video
Hey pls help me.. I have this Hotel Tv 25HT4672/69R code 3,1,9,7,5,3 and pressing mute button didn't worked.
PHILIPS 21HT3252/41 TV 3,1,9,7,5,3and pressing mute button didn\'t worked PLEASE HELP ME
Jan 22, 2011 | Philips 20PT6441 20" TV
Need code for tv remote to operate tv by the remote
Hello
You cannot change Parental
Control settings without
knowing the secret code. If
your code changes, someone
else has altered it and possibly
viewed blocked channels. Yet try the following procedure:-
Philips sets uses a four digit code to contro the V-Chip. The override code for Philips set is " 0711 "
OK.
Dec 28, 2010 | Philips Magnavox 27MS343S 27" TV
El tv dice blocked by autolock channel blocking access code
Hello
Your TV is locked I thinks.
Read this well before you proceed
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code , and enter a second time it it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, goto BLOCK, and push the "right arrow" key. Go to Blocking Options and press "right arrow" key. Goto master disable and press the right arrow key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Dec 04, 2010 | Philips Magnavox 27MS343S 27" TV
I purchased a used Phillips TV 30PW8502/37. How do I disconnect the autolock feature when I do not know the Access Code?
the code for this tv is as follow press and hold stdby and mute at same time then key in 319753 then press mute this lets you into the menu. these tvs where set up for hotel use but can be set up for as other.
Nov 27, 2010 | Philips Televison & Video
How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
Jun 30, 2009 | Philips 20PT6441 20" TV
hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
raveendramax@gmail.com
Aug 14, 2008 | Philips 20PT6441 20" TV
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
