Question about Regal Ware GL2850 Bread Maker
I have a regal bread machine, but am missing the part that stirs and kneads the bread on the inside of the pan. Is there somewhere I can just get that replacement part?
  • 320 Answers
Please refer from the link below to contact the manufacturer on where to purchase the parts that you are looking.
http://www.regalware.com/
Posted on Nov 07, 2010
I hvae a Regal K6726 Bread Machine that a friend gave me. When I went to use it the first time, the Kneading Blade did not turn and the bread did not mix. It made a clicking sound, but did not turn. When I...
Hi...Take the empty pan out of the machine and spin the paddle by hand. It should turn freely with no sticking and should not be loose. There is a sealed bearing on the bottom of the bread pan and if this fails then the paddle will stick and be really loose if you try to move the paddle up and down. . If this is okay then check the belts and gear. They could be loose or worn out. Belts and motor are located in base of machine. Be sure to unplug before checking this out. Also, make sure bread pan is installed in the machine correctly. Hank
Jan 17, 2011 | Regal Ware Kitchen Appliances - Others
The rubber (?) gasket between the kneading blade and the bottom of the bread pan has deteriorated and sluffed off into bread. Can I get a replacement?
Hi, That is actually a sealed bearing that the paddle shaft rotates on. It can not be replaced and you will need a new bread pan. Regal does not make bread machines anymore, but you may find one on eBay or Amazon. Hank
Dec 05, 2010 | Regal Ware Kitchen Appliances - Others
Drive shaft no longer turns kneading blade on model k6725
Either the paddle is frozen in the bread pan ( take pan & paddle out of machine and see if you can turn it by hand), or the belt has fallen off or has snapped. (Keep the bread pan out of the machine & run a knead cycle, look through the lid window and see if the motor shaft spins. Hank
Mar 05, 2010 | Regal Ware Kitchen Appliances - Others
Help - the stirrer keeps sticking, the motor strains to turn it round but it won't go when the dough is in, its too heavy. The last loaf I made I had to take the dough out of the machine and kneed it...
Take the bread pan out of the machine and run a kneading cycle. See if the motor is straining. If it is it could be a belt or the motor itself. If the motor runs nice and smooth and you can see the motor shaft spinning effortlessly, then it's the bread pan itself. See if you can spin the paddle easily when it is out of the machine. If not then it is the sealed bearing in the bread pan that is starting to fail and it's time for a new bread pan. Hank
Dec 13, 2009 | Kitchen Appliances - Others
I love my bread machine, model 5890, but with every loaf of bread the kneading blade stays inside the bread. The bread is also difficult to take out of the pan. This has led to scratches in the pan as...
I usually take the paddle out of the machine at the end of the kneading cycle and before the rise cycle. (Do this with the pan out of the machine..just in case). You don't want to use anything in the pan that will scratch it. Usually a few quick taps of the bread pan on the cutting board will free the bread.
Dec 05, 2009 | Sunbeam 5890 ExpressBake Bread Maker
Kneading blade stays in the bread
I had that problem with my Zoji breadmaker. I sprayed a little non-stick spray on the blad and it worked. You can also spray the pan.
Jan 06, 2009 | Sunbeam 5890 ExpressBake Bread Maker
Bread machine pan and kneading blade
here's the manual if you need it http://www.bread-maker.net/Bread-maker-reviews/Product%20Manuals/Betty-Crocker-BCF1690.pdf freefone for spares from manufacturer: 1-866-819-4335 hope this helps :)
Mar 06, 2007 | Betty Crocker BCF1690 Bread Maker
Regal Ware GL2850 Bread Maker Logo
32 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
Irene Tulloch
Ruth summersides
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
