Question about Goldstar GR131CN Compact Refrigerator
Goldstar small refrigerator
It is running but not getting cold. Does it need freon?
  • 525 Answers
If this not a frost free unit, then, based on what little information you provided, I can only say...maybe. This can easily be diagnosed if you can tap into the sealed system and do a pressure test, this will determine if you need freon. Most manufacturers put a 5 year warranty on the sealed system.
Posted on Jun 15, 2008
  • Renee Summerville May 03, 2014
    don't know how to do that
    I bought this off of someone from fb fleamarket they assured me me it worked but it don't when you plug it in it turns on but don't get cold. The things in the back on the bottom get really hot. if you turn it off you have to unplug it then plug it back in to turn it on again
Model#1051 small dorm size...doesn't matter where i set thermostat..it sill freezes everything,,,suggestions?
Repace thermostat. You didn't tell us that it runs ALL the time. It does. You don't have to tell me, I know it does. The first thing the power does is go thru the thermostat and its job is to turn the power off to the pump when it gets cold enough. If it gets cold and freezes everything then everything else is working right. There is no fixing the old thermostat either. That little tube that looks like a heavy bare wire ending next to the freezer coil has a little "freon" in it that expandes and contrectes with temp. change and the change in pressure is what ativates the thermostat. Chances are the "freon" leaked out.
Note, this is not the same "freon" that is pumped around the fridge to cool things. This is sealed in the thermostat and tube only.
Jun 23, 2011 | Goldstar GR131CN Compact Refrigerator
Ac not cold
mcdevito75 here 90% chance your low on freon, you don"t cahrge it the a.c repair shop does, you"d need the gas first and it's a commercial item then the tools would cost you the same if you charged it anyway and the shop gives a guarantee.
Jun 21, 2010 | Goldstar M5200R Air Conditioner
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
T-23 Refrigerator quit cooling.
Look in the back see if that compressor is running. It is balck kinda ball shaped. It pumps freon so to make the refrigerator cold. If it runs but do not get cold then it needs freon.
Jan 05, 2010 | True Food VWR Storage Refrigerators with...
My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
Oct 07, 2009 | U-Line ?chelon 2175RB-00
Air conditoner model gwhd5000 goldstar does not cool
Hi, first you will need to know, what type refrigerant,(freon) your a/c used, if you need to add freon, there's a leak in your a/c. you will have to find and repair leak, before you can charge/ add refrigerant(freon) . automobile a/c can be easily recharge (add) to system, but your window a/c unit, has the same principles but different approach, if you don't have experience, you will have to call mechanic, make sure you have a freon leak, before calling mechanic, plug a/c on let it work, put hands close to a/c, feel or check temperature of air blowing out from a/c, make sure compressor is working/running, fans could be working/ but compressor not, also put a/c thermostat to max, your model no. GWHD5000. means your unit is 5000 b.t.u, (british thermal unit) measurement of heat transfer, am wondering if a/c is to small for your space/room. making you think it needs freon, 5000. b.t.u. is for a small space,like a room 10' by 10' like a storage area or small bedroom, keep bedroom door/windows shut. measure you room/space/area , the bigger space/area needed to be cooled, has a chart, maybe you can find it on internet, any way a 10.000 or 12.000 b.t.u a/c is better buy, for normal room/space etc. so check compressor especially to make sure working, a/c could be to small for space/room, check it at night to see if it's colder. don't try to put gas/ freon yourself, could be very dangerous. but before calling mechanic, check those thing, mention before, could be your a/c are to small, for space/room etc. remember before attempting any repairs, disconnect power. good luck.
Aug 20, 2009 | LG Goldstar GWHD5000 wall/window Air...
Air conditioner is not cooling. The fan is running. When I turn the thermostat past 7, the unit shuts down. Any ideas? Low on Freon?
Sounds like a leak to me - if you have a set of guages available (know anyone working in the refrigeration field???) you could tell this for certain.  Otherwise, try running it when it cools down outside and see what happens.  Take a stick thermometer, and put it in between the fins on the INSIDE condenser coil.  If they get cooler, but not down to about 50 degrees, then you are low on refrigerant.
Good Luck!
May 26, 2009 | Heating & Cooling
Refrigerator is blowing air but no longer cold.
It is possible that if the compressor is running that it is either low on freon and not cooling or in some instances low on freon and evaporator is froze up - in which case frig will cool again once all the ice has melted on your floor,) Or maybe your compressor is not running - in which case its cheaper to get a new frig for sure. Listen to tell if the compressor is running. If it is, then your frig probably is low on freon. (I don't know if yours is new enough for a timer) Hope this helps you, Rick
May 05, 2009 | Refrigerators
Refrigerators Logo
545 people viewed this question
Top Goldstar Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
