Question about Kodak EasyShare DX3600 Zoom Digital Camera
When I switch it on the lens will not come out like it used to.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 08, 2010
Testimonial: "Putting in new batteries worked."
Olympus om 30 manual
The OM-30 has focusing system limitations. Most of the time, you can use the LED in the viewfinder to help you focus an image. If the lens you attach has a maximum aperture of F4 or smaller, (F5.6, etc) you set this switch to F4, then focus the lens manually using the prism gridlines visible in the viewfinder.
In short, just set the F4/F2 switch to whichever is the closest to the maximum aperture of the lens you are using. With an F1.8 lens, for example, you would use the F2 setting. For a lens with a maximum aperture of F3.5, you would use the F4 switch setting.
Aug 19, 2014 | Olympus Om Auto Extension Tube 7 For Om-1...
Autofocus lens frozen
What do you mean with autofocus lens frozen?
What lens do you use, and what are the settings on your camera. Even when you have chosen automatic on the main dail, to the left of the lens is a switch on the camera, that can be set to manual. Even on a lot of AF lenses, are switches that can be set to manual.
In your camera only modern AF lenses with Nikon F connection will work with AF. The older AF lenses (Mechanical focus) need a focus motor in the camera body, only found in the camera's that also have a little LCD screen on top of the camera. (Not in 3x00, or 5x00 models)
But if you are sure this lens worked in your camera before, please check the switches on the camera and on the lens.
Still problems? tell me what lens you are using and how is the switch AF / M on your camera now?
Dec 01, 2013 | Nikon D3100 Digital Camera
Autofocus is not working
Could you please precise the circumstances?
What lens are you using? Is there a switch (A)uto/(M)anual on the lens?
What are the positions of the switches on the lens and on the camera body(C/S/M)?
My guess either your camera or the lens are switched in the M(manual) mode.
But, sure, it could be also caused by using the old manual lens or camera/lens malfunction.
So please be as precise as you could. And we will find a solution ) Thanks
Mar 21, 2011 | Canon EOS Rebel XSi Digital Camera
Hallo, when I switch on it says "please turn
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 30, 2010 | Panasonic DMC-FX37 Digital Camera
My Nikon D40 can only be used in MANUAL mode. I was able to take photos using MANULA mode but for all other modes it says: "lens not attached" even if the lens is properly attached.
What lens are you using ?
For all functions to work you will need a cpu lens - ie; a hsm or afs lens,these are lenses with built in motors.
Also check the switch on the side of the lens is switched to (A)
Jan 03, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
The 18-55 lens will not focus when I shoot. Niukon D50 camera
Make sure that the A/M switch on the lens is set to A (If your 18-55 has that switch, not all do) and also the A/M switch on the camera body is set to A.
Nov 30, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
My Olympus FE-230 makes buzzing noise when switched on and lens goes in and out and won't switch off and won't focus
Check for specks and chips on the lens first, if there are spots in the images. Take the lens off the camera and look through it at a low-level light source. If there is dust or lint, clean the external elements according to Olympus recommendations. Look through the lens again. If there still are spots, there may be dust on the internal elements. You will need to take the lens apart to clean each lens element. Taking the lens apart is a delicate procedure. Use Phillips-head screwdrivers or the Japanese crosshatch type. Lay out the lens and screwdrivers on a soft, lint-free cloth, and place each part of the lens in the correct order so that you can remember how to replace them. Clean each element with soft lens tissue or cloth or use a manufacturer-specific kit.
Aug 28, 2009 | Olympus FE-230 Digital Camera
Canon 30D
Is the lens a Canon EF or EF-S lens? Have you used it before on this particular camera body? Did you do anything else (change memory cards, etc.) at the same time you changed the lens?
Try taking off the lens and cleaning the electrical (metal) contacts on both the lens and the body with a small dust-free cloth or pencil eraser. If that doesn't help, switch in the lens you were using before. If it works with the original lens, there may be an electrical problem with the other one. If it no longer works with the original lens, you may need to have it serviced.
Feb 08, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Kodak EasyShare DX3600 Zoom Digital Camera Logo
37 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
