Question about Crosley CAWC529JQ Top Load Washer
I have a crosley portable washer, model cawc529pq and the power button keeps blinking. i cant turn it off...i even unplugged it and keeps blinking as if the lid is open but its not...so now its filled with water and i cant restart it or anything,,,do you what is wrong with it or if there is a reset button..i tried unplugging it for hrs, i even took the wet clothers out of it thinking it was unbalanced but it keeps blinking and wont come on or wash at all....please help
  • 105 Answers
SOURCE: crosley washing machine
the drain pump is blocked and will need to be cleaned out as the humming is comming from that pump motor by the sounds of it
so check that
cheers
Posted on Mar 16, 2008
  • 105 Answers
SOURCE: Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
  • 47 Answers
SOURCE: Washer did not spin
JERRY,
IT SOUNDS LIKE YOU GOT TAKEN ON THIS WASHER. A NEW WASHER NORMALY WORKS, BUT IN SOME INSTANCES, LIKE YOUR CASE, IT COULD BE THE BELT OR THE MOTOR COUPLING. WHAT I WOULD DO IS CALL THE PLACE WHERE YOU GOT YOUR WASHER FROM AND HAVE THEM TO BRING YOU A NEW REPLACEMENT. THERE HAVE BEEN COMPLAINTS ABOUT WASHING MACHINES NOT WORKING RIGHT WHEN THEY WERE NEW. I HOPE THIS HELPS YOU AND ANYBODY ELSE WHO READS THIS WEBSIT, BECAUSE THERE IS NO SENSE IN THE STORE SELLING A BRAND NEW WASHER WHEN IT ALREADY LEAKS.
RODNEY
Posted on May 14, 2009
SOURCE: Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Posted on Jan 09, 2010
  • 714 Answers
SOURCE: washer keeps draining, it won't shut off unless
sounds like a timer problem
Posted on Jan 17, 2010
Testimonial: "Thanks for the answer I will replace the timer and see what happens. That is kind of what I thought too."
I have a crosley cawc529pq washer that washes but
Hello friend, thanks for your post!
Based off the information you have provided your Crosley washer is not spinning. I would check to assure that the drain hose is not restricted or kinked. Anything blocking the hose from draining properly will cause your washer to not spin.
If these hose checks out to be fine, I would suggest a potential issue with the motor or control panel of your washer. If parts are needed to be replaced I would recommend you speak with a professional for further diagnosis and repair. I hope this information has been helpful. -Matt
Oct 18, 2014 | Washing Machines
Spin light is blinking on my crosley washer
check belt is not Brocken filter is cleaned also can be the motor not turning check brushes or that the motor is not burned
Aug 13, 2014 | Crosley caw9244xq 3.4 cubic foot white...
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
Nov 25, 2012 | Crosley CCW5294W Top Load Washer
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My crosley washer filled with water and stopped working. the water level light is blinking, but it won't finish the cycle. can you tell me what the problem is?
there may be a problem with the pressure switch.there may also be a problem witht the lid switch.try and unplug the unit and see what happens.
the main control board would be the last thing to go out and need replaceing
Jan 31, 2010 | Crosley CCW5294W Top Load Washer
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
    Try this:
    1. Turn off printer (use button, don't unplug)
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    If this not help may the print head is defective.
    Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
    Error messege, front loader wont start.
    my name is joyce
    first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
    joyce
    Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
    Crosley CAWC529JQ Top Load Washer Logo
    113 people viewed this question
    Top Crosley Washing Machines Experts
    Dan Webster
    Dan Webster
    jdthefixer
    Karl H
    Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
