Question about Eemax SP2412 "Single Point" Electric Tankless Water Heater
Is a Eemax Electric Tankless Water heaters model sp2412 a good water heater
dragonsthatk
  • 547 Answers
SOURCE: no hot water
in and out hooked up right?
Posted on May 17, 2009
gary1121
  • 332 Answers
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Posted on May 29, 2009
  • 11 Answers
SOURCE: takes too long for hot water.
You need a recirculating line. You will have to hire a plumber to run a water line from the farthest fixture or to the fixture you are concerned about on the hot side and return it back to the water heater. this will cause hot water to constantly run throught the hot water line (via the recirculating line) and when you want to draw water from the fixture, you will already have hot water right at the line.
I know this works with standard tank water heaters, but it is a lil trickier with rinnai units(but very possible) if your plumber pleads the 5th and tries to sell you another unit call the Rinnai manufacturerand ask them how.
Posted on Jun 20, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
SOURCE: trips breaker
If it trips the breaker you MUST have an Earth fault and or a short circuit to Neutral/Earth. You must get a Registered Electrician to look at it.
Posted on Feb 03, 2010
No water coming out from outlet.
What product? eemax sp2412/
http://www.homedepot.com/catalog/pdfimages/e2/e289142e-792b-48ed-9b6a-bae87550a046.pdf
Is this new installation or older installtion that worked before?
Have you cleaned the inlet water filter?
Hs unit exposed to hard water?
Has unit been delimed before?
Have you disconnected supply line under sink to see if problem is faucet?
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 31, 2013 | Eemax SP2412 2.4kW 120V
Hot water not coming out
Tank-type Electric water heater?
Press reset button.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add comment and describe water heater, and more detail about problem
Mar 30, 2013 | Eemax "Flow Controlled" Electric Tankless...
How can i to change the element of the eemax ex95?
http://www.eemaxinc.com/assets/files/Series%202-trouble.pdf
May 15, 2011 | Eemax EX95 "Flow Controlled" Electric...
Wher does white wire go on ex 190 eemax water heater
It runs off 220v, meaning there are two "hots" and a ground. The 190tc uses TWO sets of 220v at 40amps each. Instead of only having one dbl throw breaker, you need 2. Having said that... the white wire "should" be the same as the black wire and can be connected which ever way you like
Jan 17, 2011 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
My house has 200 AMP Service, will this work ok with the EEMAX EX380T2T2? It requires 4 40AMP Breakers.
your water heater will take a 160 amps of you service. I would not install one if it was me. The total demand in the dead of winter with furnace, water heater and lights on will cause you to brown out.
Oct 05, 2010 | Eemax EX380T2T2 Series 4 Whole House...
The center heating element is no working. How much does a replacement element cost?
the price will vary in different localities.
you should call a plumbing wholsaler in your area. Home depot and Lowes will not carry these, neither will you local hardware store.
the replacement is faily simple. Eemax is a nice heater, although faily expensive to opperate.
Aug 20, 2010 | Eemax EX280T2T Series 3 Whole House...
Only have warm water,all elements are good ,no lights on last two chambers
It seems you have had little luck with a direct answer or chat...perhaps their website will help? Try here.
Dec 18, 2009 | Eemax EX280T2T Series 3 Whole House...
No hot water
check circut breaker reset it then chek for power on both legs.
Aug 18, 2009 | Eemax EX280T2T Series 3 Whole House...
No hot water
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
Eemax SP2412 "Single Point" Electric Tankless Water Heater Logo
Top Eemax Water Heaters Experts
Donni Steen
Are you an Eemax Water Heater Expert? Answer questions, earn points and help others
