My computer is making a "motor" sound. When I reboot it, it stops for a few minutes then starts up and does not stop until I turn my computer off. What could the sound be?
  • 31 Answers
Hard drive sound, u should replace hard drive
Posted on Nov 07, 2010
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
I have a Tempstar 5000 that is about 15 yrs old and the fan motor to the outside unit will suddenly stop working and the compressor will start making a loud humming sound that does not sound too good. I...
Hello
Sounds like the condensor fan motor is going bad.If the fan stops turning or is not turning at full speed, the compressor can not give off heat to the condensor.Which will cause it to shut down on high heat.
So i would start with a new fan motor.Your local heating and cooling supply house should have these in stock.
Aug 01, 2011 | Heating & Cooling
Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
Jun 04, 2011 | Dishwashers
My machine is LG intello washer 7.5kg WD-1025FB the machine can start work, but after few minutes, it stopped and only can hear motor making noise. i turn of the switch start again, same as before: work...
Sounds like you may need new timer. They have contacts in side that control all fuctions of you machine if those contacts start failing or get burnt the machine will hit a certain spot in the timing and then it will stop or stall.
May 04, 2011 | LG Washing Machines
Dryer has stopped running in all modes. Timer makes a ticking/pulsing sound in "timed heat". Makes no sound in other modes. Origianlly stopped working when it was very hot. Next few tries ran a...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 04, 2011 | Dryers
Pump starts and stops after few minutes
Sounds like your motor is overheating, This is a sign of windings going bad and sorry to say you will probally have to replace the motor.
May 18, 2009 | Jandy In-Ground Plus HP Pump
Bought 2002 Cal Spa and the motor starts and stops repeatedly
It sounds like the motor is running to hot and cutting itself off as a safety. Make sure that the wiring is correct, and if it is you may need to replace the bearings (if the motor is running very loud or making a grinding sound). or you may just have to replace the motor.
It could also be a problem with the control panel. Do you hear the relay click on and off with the pump?
Check the voltage at the back of the motor with a voltmeter and make sure that it is 110vac and that it is there throughout the cycle.
Apr 01, 2009 | Jacuzzi Pool & Spa
Dryer problem
Hi. thanks for the question . It looks like you have a faulty motor . I would replace the motor , thanks the appliance doc
Sep 20, 2008 | Kenmore 72802 Gas Dryer
System test?
sounds like ye olden sound drivers are unhappy. or the sound card is taking early retirement. check drivers first..if you can't find out what sort of drivers you have, send me a note to pn4pm@yahoo.com and we'll arrange a shared screen session
Feb 18, 2008 | Dell WL6000 Computer Speakers
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
