Question about Samsung WF203ANW Front Load Washer
WHAT DOES ERROR CODE E2 ON A SAMSUNG BIG WASH WASHING MACHINE MEAN
milten1
  • 1304 Answers
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Posted on Oct 20, 2009
SOURCE: samsung washing machine
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Posted on Feb 15, 2008
  • 26 Answers
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Posted on Nov 19, 2008
SOURCE: i have a j1453 washing
6E error means ambient temperature is too low.
A problem that occurs when the potentiometer connected in series with the thermistor on the microprocessor board is damaged.
for more details try this link:-
http://applianceguru.com/view_topic.php?id=3721&forum_id=2&jump_to=95478
As this is under generic problems on all washing machines, the link will surely help.
Posted on Dec 13, 2008
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
What does E2 error mean
Generic pump error
Error Code-control panel display "Err2" (Error 2, Error2) ' question ...
www.haier.com/za/help.../washing_machine/.../question/.../t20140313_209219.shtml
  1. Cached
  2. Similar
Mar 13, 2014 - Error message:Drain error, water can be not drained fully within the required drain time (controlled by PCB software). Reason 1. Pump filter is blocked. Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine). Step 1.Push a flat blade ...
How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front ...
9k=? 5:23 https://www.youtube.com/watch?v=by94vOVmmhQ
  1. Similar
Mar 18, 2017 - Uploaded by Nancy Gurish How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front Load Washer Stopped, Repair Of ...
Washing Machine Error Codes - Front Load and Top Load Washers ...
https://removeandreplace.com/.../washing-machine-error-codes-front-and-top-load/
  1. Cached
  2. Similar
May 5, 2015 - F9 followed by E1 - (drain pump system error) F5 followed by E2 - (door will not lock) F7 followed by E1 - (motor drive error) "rL" - (remove load) Washer making error beeps - Door has not been opened and closed for at least 3 cycles. Washer beeps when HOLD TO START is touched - Door not closed
Mar 22, 2018 | Washing Machines
What does the fault code e2 mean?
Kenmore e2 code Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > e2 code > Washing Machines
Kenmore washing machines e2 code related questions and answers. Ask yourKenmore questions. Get free help from washing machine experts.
Jul 26, 2015 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Hi i have a bosch classic maxx washing machine WAE20260AU with probalm E2 what do i do now?
As you said in the question you are washing machine is showing the error code as E2 is nothing but Error signal due to long heating.If you want to get repair means you just need to contact you are nearest service center for service engineer.Thanks for your question.
Jun 20, 2011 | Bosch Washing Machines
Dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Jan 11, 2009 | Maytag EPIC MFW9700S Front Load Washer
Error E2
It is drain pum error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Good Luck
Jan 08, 2009 | Washing Machines
Samsung WF203ANW Front Load Washer Logo
1,753 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
