Question about HandHeld Entertainment AvMap EKP-IV Aviation GPS
Where can I get repair parts for my AvMap ekp-IV I need the cursur button repaired ant the antena plue inside the unit
2 Suggested Answers
SOURCE: avmap ekp iv
Dahhh you think!!!
Posted on Aug 02, 2008
I had my system cleaned and upgraded at Office Depot, Pensacola, FL. My cursur is going crazy. It is hard to type anything and have to make sure cursur is in the right place. Please let me know what to...
Personally i would not attempt any kind of diagnostic or repair here. If it was stripped to be cleaned, the most likely cause of the problem is that they have not properly connected the mousepad ribbon cable, resulting in erratic movements. Take it back and ask them to repair it.
Mar 28, 2011 | Computers & Internet
How to update Amap EKP IV. I downloaded a zipped file to the computer. In the zipped file are two files that match files on the compac card. If I move the zipped file to the compact card will the GPS do...
In order to update your EKP you need a CF reader, you cannot update your CF without it.
First of all download and unzip the update files from our support section.
Enable the show of hidden files. Create on your Desktop the folder 'Old CF'
and copy in it all the files from the CF (is the backup folder if something goes wrong).
Omit to copy the 'CHARTS' folder. Create on your Desktop the folder 'New CF'
and copy in it the same files you copied in 'Old CF'. Replace the files format swx
in 'New CF' with the ones you downloaded from internet. Ovewrite the files in the cF
with the ones in 'New CF' (do not touch the CHART folder). Turn on the EKP and verify
if the procedure was correctly executed. If not, reinstall in the CF the files from
'Old CF' and repeat the procedure.
NOTE! : this procedure can delete all user marks from the RAM. Save them first in the CF
with File Manager.
NOTE! For the update of 21/oct/10 you will need to update the Jeppesen cycle to !
Feb 06, 2011 | HandHeld Entertainment AvMap EKP-IV...
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
Pontiac vibe broken antena
Unscrew the top cap and remove it. Then Lower the antenna to see if there is a swivel you have to hold vertical to get it through the hole . the cable needs to be disconnected from the radio Get a new ant. and you will see the swivel uou need to hold vertical. good luck.
Jun 02, 2009 | 2005 Pontiac Vibe
Need to reset unit to factory specs
Called up the AVmap site online and the answer was right on their website.
May 01, 2009 | GPS
IQUE M5 Antenna broke off
BUY PART NUKMBER 010-10702-00 FROM GARMIN IT IS A EXTERNAL ANTENA THAT PLUGS RIGHT INTO THE UNIT.
Feb 06, 2009 | Garmin iQue M5 GPS Receiver
Avmap ekp iv
Hello weertobal,
Where are you using the GPS when this is happening? In order to get a fix on its own location the GPS receiver needs to receive telemetry information from four or more GPS satellites. In order to get this data, the receiver needs a clear view of the sky.
If you are using the GPS indoors, in an area with a lot of obstructions such as mountains, trees or tall buildings or in an automobile or vehicle without an external antenna, then your GPS may not have a clear view of the sky. This can cause it to be unable to get a fix on its own location or it may take a very long time to aquire a fix.
If the problem persists when you are using the GPS outdoors with a clear view of the sky, then this may be a sign of a more serious problem that could require service.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 18, 2008 | HandHeld Entertainment AvMap EKP-IV...
Insufficient range
Yes, there are several solution to your problem base on your line of sight. If your unit allow you to remove the external Ant., purchase Netgear ANT2409 odbi omni-directional antena indoor/outdoor and screw it on to your unit. Amplified Ant., are also available to get the job done or add a Netgear Wireless access point to your network!
Coach "J"
Have a great 2008!
Jan 08, 2008 | NetGear RangeMax WPN824 Wireless Kit
Orion tv model # stv 2762
your que. is not clear but if you asking for a socket goes to antena is available at any tv spare parts shop.
Sep 28, 2007 | Televison & Video
HandHeld Entertainment AvMap EKP-IV Aviation GPS Logo
61 people viewed this question
Top HandHeld Entertainment GPS Experts
Are you a HandHeld Entertainment GPS Expert? Answer questions, earn points and help others
