Question about Brother CS-8072 Computerized Sewing Machine
My machine seized up. the serviceman oiled it and it ran smoothly at the shop. I was using another machine and didn't use it right away when I got it home. That was several months ago. Today I get it out to use and it runs smoothly but the stitch it makes is like a chain stitch that unravels. It will not sew a regular locked stitch. Why is that? I have changed the needle, rethreaded, replaced the bobbin...what do you suggest? Thank you.
  • 208 Answers
It's very important that the needle is inserted with the flat side of its shank facing to the back. If that is correct, perhaps the timing of the hook and needle was changed when the machine seized up. Take off the needle plate and remove the bobbin case. With the handwheel moving in the sewing direction, when the needle has reached its lowest point and has moved up 2.5 millimeters the point of the hook should be directly behind the needle. If not, take it to your repair person.
Posted on Nov 07, 2010
The selector lever doesnt work on my bernina 1030 it will only sew straight and ziz zag stitch can it be fixed
Yes, most likely the mechanics are seized due to old oil that has dried. I have a 930 that I frequently clean & lube thoroughly to keep it running smoothly. The only thing is to stay away from the basting stitch mechanism (sorry, can't remember if your machine has it) located in the middle of the needlebar directly behind the take-up lever. Once you give your machine a good lube, you'll be amazed at how quietly and smoothly it runs.
Wheel on right side that controls the needle up and down is very tight...
Here's a Service Manual for your machine:
https://www.manualslib.com/manual/1059902/Bernina-1030.html#manual
Only a caveat, but is generally recommended to NOT use compressed air to clean sewing machines. Frequently, it pushes the lint and dust further into the machine so a technician will have to clean it.
Nov 02, 2017 | Bernina Sewing Machines
Should I oil my Singer 6235 machine?It has not been used for 20 years, but seems to sew well.
Because your machine is an older mechanical, it most likely would benefit from a thorough clean and oil. Even though it still sews well, the moving parts may be dry and need some lubrication to keep it running smoothly and quietly. At some point it very well could begin to seize. Even if it runs well, you will most likely notice a difference in the sound and operation after some TLC.
Oct 07, 2017 | Singer Sewing Machines
Bernina 1010 reverse knob is stuck in the up position. Only sews backwards.
It's an older mechanical, right? Most likely it has seized due to old oil that has dried.
I've used the following method on a seized 930 and it is purring away now.
Sep 27, 2017 | Bernina Sewing Machines
Bernina minimatic 707 - needle isn't going up and down. I've turned the hand wheel away from me but the machine isn't sewing? Is there something else I have pressed?
Ooh, do not turn the handwheel backward. Most newer machines have a lock that prevents this.
If you had it serviced recently, take it back immediately. This indicates to me they didn't address some existing issues.
It would be difficult to diagnose without seeing the machine operate. If it worked for a couple hours and then seized, I would be tempted to oil again with Tri-Flow Synthetic Lube and follow up with heated air from a handheld hairdryer. (I've had to repeat the process several times on some seized machines before they are fully loosened and operating smoothly.) However, the clunky sound could be disconcerting.
Sep 19, 2016 | Bernina Sewing Machines
Juki DDL-8700 wheel not turning. Initially running fine, after a few minutes, wheel seizes. Machine is oiled, and we can see oil in the viewing window, Machine looks very clean inside. Motor sounds
Have you tried cleaning it? Sometimes a piece of thread or some fuzz gets in between the parts and causes friction. If you have a manual, or can get one online, you should walk through the pages on cleaning and do each and every part of the cleaning. If that doesn't work, call a professional. There are service people who come out to your shop and work on industrial machines. Mine charges $55, plus parts if needed.
Nov 02, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Where do I oil my TACSEW T 1718?
Most machines need oil where metal parts connect, interact or rub together. It is useful to first clean any old or gummed up oil away. Varsol or paint thinner is good for that. Wipe it all away, then put a single drop of sewing machine oil, not any other kind, on each spot metal parts interact. Turn the machine over and check for places underneath, see if any doors open on the top or side of the machine, or if you can remove screws to give access to the working parts inside. If you see tiny holes that don't have screws in them, these may be oil ports. If they are above otherwise inaccessible areas where metal meets metal, a drop of oil in one of these is appropriate. Set the machine on a towel or something for a day or two in case it drips excess oil. Best to be very sparing with the oil, one drop per location is usually enough. When done, turn the hand wheel and see if all is moving smoothly. If not, another drop where any part is binding may help. If it won't work after that, you need a repair man, as something may be seized. Never force anything if it's not moving properly, you can break off a gear tooth or damage a lever and parts for old machines are not so easy to get sometimes.
Oct 09, 2014 | Sewing Machines
362 pfaff does it overheat or what, it runs smoothly couple of minutes and then it gets slower and slower until it doesn´t want to move at all. I let them cool down for a while and then it works...
Actually, its seizing up due to a lack of oil. This is common when machines aren't being serviced on a regular basis. The machine is seizing after being used because everything expands when it heats up.
Feb 16, 2010 | Sewing Machines
My very old Elna Super foot pedal does not always start the machine. When I help it along with the wheel it might start going and then maybe not. Is it the motor or the foot peddle that is bad? Can it...
this sounds like the internal clutch drive is worn, it probably is not the foot pedal at all. It may be possible to repair it if you can track down an Elna serviceman. My Air Electronic SU got worn internally and my serviceman was able to repair it once for me.
Oct 28, 2009 | Elna 2007 Mechanical Sewing Machine
Brother CS-8072 Computerized Sewing Machine Logo
284 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
