Question about Kenmore Washing Machines
Hello, I just bought a used Kenmore machine, it rinse washes but it doesn't drains the water or spins at the. Is it something that I am not doing right? or could it be that the machine is faulty. Are there any special instructions to run washing machine??. thanks,
    Genius:
  • 1,672 Answers
Check the power. If your Kenmore washing machine does not operate at all, you may need to replace defective or blown fuses or reset a tripped circuit breaker. This is done by moving the lever to the "Off" position and back to "On."
  • Examine the lid switch to see if it is defective. A malfunctioning switch can prevent the machine from operating or spinning. The switch can be found on the inside close to the door frame. Some models also have a special "lid-switch" fuse close by the lid switch within the control panel. A blown fuse will not allow the washer to fill with water.
  • Unclog the drain line if the machine is spinning but not pumping out water. If the problem still isn't fixed, the pump may need replacing.
  • Look for a broken pump belt or frozen water pump pulley if the machine does not spin or pump water. Test the pulley by disengaging it from the appliance and physically turning it. It should rotate freely.
  • Determine if the motor coupler or belts are broken, which could prevent the washer from spinning. Failure to spin also could be the result of a worn clutch, a malfunctioning drive motor, an improperly shifting transmission or a worn or "seized" spin bearing or basket drive. These problems also could keep a washing machine from agitating.
  • Find the source of a leak by checking the washer's air gap, inlet spout and rubber tube. Replace any items that are cracked, worn, deformed or disengaged.
  • Test the motor coupler, water-inlet valves and the drain hoses if your clothes are wet following the spin cycle. Replace these parts as needed.
  • Hope this might help u out!
  • Posted on Nov 07, 2010
    Testimonial: "Thanks, a lot for a prompt reply. i was searching the Internet and found similar solution but will definitely work on the process you stated."
    Tip
    Washing Machines will not rinse or spin
    If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
    What is wrong with a washer that does not spin?
    If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
    How to Drain Washing Machine That Won Drain Family Handyman
    Washer Doesnt Agitate or Spin
    Error codes in front load washers
    Washing Machine Not Rinsing How To Fix
    My washing machine stops at Rinse Does not DRAIN or SPIN
    What causes a washing machine not to drain and spin?
    If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
    SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
    Maytag Washing Machines will not rinse or spin Google Search
    on Dec 12, 2017 | Washing Machines
    Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
    see the next steps and use the common sense: God bless you
    When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Aug 01, 2012 | Washing Machines
    Kenmore washer doesn't drain
    This is likely a pressure switch issue.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    May 27, 2009 | Kenmore Washing Machines
    Spin/drain cycle won't start
    If the timer gets to the rinse cycle and stops,
    Check the lid switch for continuity. If no continuity replace the lid switch.
    If the timer continues through rinse and spin without doing either, replace the timer.
    May 21, 2009 | Kenmore Washing Machines
    Kenmore model 22432100 - it won't drain or spin
    sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
    Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
    Won't spin or drain
    Check to make sure your lid switch is working.
    Nov 17, 2008 | Kenmore 22422 Top Load Washer
    Kenmore elite washer problem
    sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
    Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    144 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
