Question about Kenmore Elite HE5t Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
  • Kenmore Master
  • 19,396 Answers
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Posted on Jan 13, 2011
Fault code f71 door locked. Is there any way to open door?
Here is a page tells you what to do to try to fix the issue. As it says if it persists Have it looked at. Page 23 of Kenmore Washer User Manual ManualsOnline com
Sep 30, 2014 | Kenmore Elite HE5t Washer
What do the following codes mean: F70 and F71. My washer is a Kenmore Elite HE5t. Thank you
The F70&F71 mean basically the same thing
F70 means the main control board is not communicating with the cycle selector/touch pad control
F71 means the cycle selector/touch pad controlis not communicating with the main control board
What needs to be checked is the wires between the main control(CCU) and the selector(user interface) for good tight connections
If all connections are good and tight the CCU has to be replaced IF the drum will rotate under power from the motor
OR if the drum will NOT rotate under power of the motor the USER INTERFACE needs to be replaced
Gene
Aug 18, 2011 | Kenmore Washing Machines
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
F71. unplugged & plugged it back. now no lights, no F71 code, nothing works
Hi
Thanks for using FixYa. Error F71 is User Interface Heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit. To resolve this issue you’ll have to:
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Kenmore Elite HE5t Washer
He5t washer keeps flashing F71.
The F71 and F70 are difficult error codes to pin down even for a technician.
The F71 indicates a user interface heartbeat error while the F70 indicates a heartbeat error in the central control.
There is a quick test you can try to resolve the problem. 1. Lock the control by pressing and holding the cycle signal button. 2). Press the Power button.
3). If the lock light flashes when you press the power button it indicates the center interface was able to take the input and the Right hand User Interface received the DCV signal from the Center User Interface but since the display did not light. This indicates an issue with the Right hand user Interface.
To know more about this error code.Please click on the link below:--
http://media.fotki.com/1_p,srgbtrqsqqqggbqxgtqsskgwtqkq,vi/dkrssrqrrxkktggsfswxrrttkgswb/1/1303472/5961857/image257713813124371901img-or.jpg
to know where the parts are located on your unit ,please click on the link directly
http://media.fotki.com/1_p,srgbtsktrrbtqqdxgtqsskgwtqkq,vi/rbkfdkgkwxbqtftkggsxrrttkgswb/1/1303472/5961857/image9163592655485290914img-or.jpg
to get required parts you can get it from www.repairclinic.com.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 09, 2010 | Kenmore Washing Machines
There is an error code f70 and there was an error code f71.
Hi.
Regards.
Ginko.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
I am repeatedly getting an F20 error on my Kenmore HE5t washer. It seams the the spin cylce before the final rinse is the sticking point. I have to unplug, restart and finish the cycle with final rinsie...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first.
Oct 12, 2009 | Kenmore Elite HE5t Washer
My kenmore he5t washer will not turn on. The on
I have the same problem . If I power cycle mine enough times I eventually get a F70 or F71 code. My research online suggests that the user interface board has a problem and needs to be replaced.
The good news is the warranty covers these boards for two years. The bad news is they are $360 if you are out of warranty.
HTH
Jun 12, 2009 | Kenmore HE5
Kenmore Elite HE5t Washer Logo
1,125 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
