Question about Fuji FinePix 2650 Digital Camera
Zoom error///lens will not come out when you turn camera on
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 08, 2010
  • Louiza Numo1 Jan 05, 2011
    Hi,well first off,thank you for your advise.
    I found the twisting and rotating whist powering on did the trick.Think lens barrel guide pins may have reseated in their guide slots.
    So,my next issue is......oh yes,there's another,may be my card?
    only takes 2pictures and says it's full???
    until next time.....happy days
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
(zoom error) massgae appear when camera turn on
You have a problem with your lens, maybe a decentered lens. Make sure there are no obstructions in the way of the lens. It may need to be serviced.
Sep 21, 2014 | FUJIFILM FinePix J30 Digital Camera
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
Fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Jan 02, 2008 | Fuji FinePix A600 Digital Camera
Fuji FinePix 2650 Digital Camera Logo
79 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
