Question about KitchenAid KCMS145J Microwave Oven
Majic Chef cabinet mounted microwave oven model VM11B-8P
The countertop light burned out. I went to unscrew the burned out bulb and an electrival spark happened. When I replaced bulb with a new one the light will not come on and neither will the fan come on??? Suspect a blown fuse but don't know if there is a fuse or if there is one where it is located and how to get to it??
  • 413 Answers
On the electronic control board, the circuit trace will open like a fuse if the light bulb power becomes shorted. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for a burned, open circuit trace.
4. Repair circuit trace everything should work again....
Posted on Jun 15, 2008
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
Replace light bulb.
Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
Mar 07, 2015 | Magic Chef CMV1000B Microwave Oven
How does one replace the light bulb in the Panasonic NN-T990SA countertop microwave?
you have to remove the plug and then the outer casewhich is 4-5 screws on the back,you will find a air duct on the left hand side of the magnetron which is a metal box with two wires on the bottom.the bulb hosing is kept in with a screw and a metal tab,undo the screw and remove the two wires and that is the unit you have to replace,it is called a cap less bulb as it is one unit,reassembly is the reverse.hope this helps regards les
Nov 03, 2014 | Panasonic NN-T990SA Microwave Oven
Magic chef overthecounter microwave external light doesn't work
This microwave's replacement countertop light is F60305H00AP. This can be obtained by going to
The instructions for replacing the bulb can be found in the below link.
Mar 02, 2014 | Panasonic NN-SD277WR - NN-SD277WR...
Will run but not heat , majic chef, model mcd990arw
check the door switches ... they are probably burned preventing preventing the machine from knowing the door is closed.
Oct 19, 2009 | Magic Chef MCM1290A Microwave Oven
Apr 13, 2009 | Microwave Ovens
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Feb 08, 2008 | Microwave Ovens
KitchenAid KCMS145J Microwave Oven Logo
281 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
