Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
My chamberlain Whisper Drive garage door opener Light's always stay on. The door is working fine without obstructions or problems but the lights do not turn off.
4 Suggested Answers
  • 3197 Answers
SOURCE: Installed Chamberlain Whisper Drive but door slides backwards
It sounds like you may have a spring problem. Release the door from the opener and see how it acts manually. Open it as far as the opener does and then see what happens when you release it. Also the weight of the door should give you a clue.
Posted on Aug 24, 2009
SOURCE: Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Posted on Dec 17, 2009
reddawgesq
  • 134 Answers
SOURCE: My chamberlain Whisper Drive HD600
Probably just a burned-out light bulb. The "click" you hear is the relay closing. Replace the bulb. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera"The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Posted on Feb 02, 2011
Chamberlain whisper drive
if you are using the new florescent bulbs they don't always seat deep enough. Unplug the opener remove the bulb in the bottom of the socket there's a metal tab use your finger or a small screwdriver and bend/lift the tab up a little bit. this should fix your problem
Aug 03, 2014 | Chamberlain 3/4-HP Whisper Drive Plus...
My new installed garage door opener closes and opens right away
You have to adjust the safety pressure sensor. It is set to too light a pressure. Check your manual for the adjustment.
Mar 10, 2013 | Chamberlain 1/2-HP Whisper Drive Belt...
My chamberlain Whisper Drive HD600 garage door opener Light's click but do not go on. The door is working fine.
Jan 31, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
Chamberlain Power Drive / Whisper Drive My garage door starts to open and immediately reverses but continues to run. I had to release the cord to allow the chain to run its course before it would stop....
It sounds like the door is your problem.
Check the counter balance spring above the door. It is likely broken.
If the door cannot be operated manually, the garage door opener will not open it either. The machine is made to operate a door that works correctly. If the door is broken, the machine will not work either.
It also sounds like the opener gears may be worn out. That also occurs because the door required service.
Jan 02, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
How can I disconnect the motion detector on the Chamberlain 3/4 HPS Whisper Drive Plus Belt Drive Garage Door Opener with EverCharge
There is a button on the side of the wall-mounted remote. It has a pic of light bulb next to it. Press it once - the motion sensor is on and the lights will be on once it senses the motion; press it again and the motion sensor will be off.
Jul 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
We have installed a chamberlain wireless keyless entry. The problem is that when our neighbors house uses their keyless entry our garage door opens without us using our code. We have checked this seveal...
We have a Chamberlain Whisper Drive Plus. The keyless entry stopped working, suddenly. I have changed the battery, not the problem. I cannot get it to work, and cannot get it to reprogram. The keypad lights up when buttons are pressed, but when I press "Enter" the whole keypad flashes for about 30 seconds and then just goes dark.
May 10, 2010 | Universal Garage Wireless Keyless Entry...
Nov 07, 2009 | Chamberlain 1/2-HP Whisper Drive Belt...
Chamberlain garage door opener won't close
read manual, if you have, on trolley engagement
May 30, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
843 people viewed this question
Top Chamberlain Building Materials Experts
Terry Smith
Level 1 Expert
Joseph Hoffmann
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
