Question about Gigabyte GA-945GM-S2 Motherboard
Cmos battery ok.But cmos distab - Gigabyte GA-945GM-S2 Motherboard
    Genius:
  • 1,672 Answers
Either way, just replce first ur battery and lets see!
Posted on Nov 07, 2010
Bios password reset cmos
Ok so reset the Bios Password? Ok well open the computer up and remove the Cmos Battery from the motherboard ....make sure to have computer unplugged and use static protection also there maybe a jumper setting to clear the cmos so check for this jumper usually in the same area as the battery after removing the battery or using the jumper to clear the cmos all you got to do is return the battery and or jumper to the original placement and your done ... just plug the computer back in and its reset.... Good luck
Oct 13, 2013 | Dell Latitude D830 Intel Core 2 Duo T7250...
Acer extensa 4220 will only boot without cmos battery?
OK, wait just a minute. You're telling me that you took the laptop apart to get to the CMOS Battery (which is on the motherboard), put it back together and have been doing this process with the cmos battery in and out? Are you sure you don't mean the battery that is on the bottom of the laptop?
If it boots with the cmos battery out that means you have to go into setup and set the date and time and possibly some other parameters every time because that little batter controls the computer's memory.
Mar 22, 2012 | Computers & Internet
Date & time not changed.
Is your cmos battery ok. It may need to be changed if it is dead this battery holds that information into the cmos settings on your computer. If it is ok you can click on the time and date that appear in the bottom right side of the tool bar and change it manually.
Mar 21, 2011 | Computers & Internet
K7t266 pro2 ver:2 the mother board can't be powered on. Could some one tell me how to check it ok please
When your motherboard/CPU board CMOS battery dry or have charge then you can not run to power *********** board.Or CMOS is disable.Please check
1 Power supply
2 CMOS Battery
Mar 15, 2010 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
Sir, I have Intel D485PEBT2 mother board.Whenever I do a cold start it does not boot.If I do CNTL+ALT+DEL it restart and boots.cmos battery is ok.date and time ok.I tried several times to change Boot...
I would suggest that you do a factory reset on your mobo. To do it, here are the steps you can follow.
1. make sure that computer is OFF and unplugged from the wall
2. locate the 3-pin jumper on the mobo that is near the cmos battery
3. once located, remove the cmos battery
4. then from the 3-pin jumper, if the jumper is connected to pins 1-2, switch it over to pins 2-3
5. return the cmos battery back
6. plug the computer back then turn it ON
7. you will probably get an option to reset or restore settings back to factory, it that's the case, continue with it
8. after doing so, turn the computer OFF again and unplug it
9 remove cmos battery then return the jumper to it's original position
10. put in the battery back then turn the computer on again
11. go to the bios and set it back to the setting that you have set it before
12. check and see if problem has been resolved
* I would suggest getting a new cmos battery if it's already old
Let me know if you need further assistance
Jon
Oct 16, 2009 | MSI MS-6547 Motherboard
Cmos battery failure even after changing the battery
may be the replaced battery is not working too. please try another battery or first make sure, the battery you placed is working ok.
May 24, 2009 | Intel Motherboard
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
No display smps ram Processor ok
Did U try to unmount the CMOS Battery and shorting the CLRTC Jumper? If not, first check whether UR CMOS Battery is OK. If the Battery is more than 1 years old, try replace it.
Mar 11, 2008 | Intel D845GVSR Motherboard
CMOS
u wann remove it so u can get in uslay buy a speaker in ther relly small looking 2 wires to it not avg desktop style ok usesaly covered also and they are very hard to find orginal replacement battery ok thx nick
Feb 03, 2008 | KDS Valiant 6480iPTD Notebook
Acer aspire e500 won't turn on
Check that all the power supply units are switched on( Wall Plug, UPS, CPU), If all is ok and the problem exists, replace the CMOS battery.( if the sys works replace your CMOS Battery, configure the cmos settings also)
Jan 03, 2008 | E-Machines T1360 PC Desktop
Gigabyte GA-945GM-S2 Motherboard Logo
Top Gigabyte Computers & Internet Experts
Alun Cox
Gbenga
Computer Links
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
