Question about NetGear DG834G Router
I'm trying to put a lock on my router - NetGear DG834G Router
  • 31 Answers
Go to 192.168.0.1 on ur internet browser and go on wireless settings then go to security and apply lock
Posted on Nov 07, 2010
How do i reset and turn off the lock on my belkin router? i have tried holding the rest button down for 2 minutes it didnt work please help!!!
there is a small button down the router on which the restore already write there if not so there is a mini hole and use a pin and put him into the hole the router will restore
Aug 02, 2011 | Computers & Internet
How do i put a lock on my wireless router
Are you trying to lock it so no one can connect to your network, or lock it so that no one can access the setup? If you're trying to make it so no one can connect to your network, go to your router setup page(192.168.1.1). If you haven't changed the password for the setup page, it should be Username: admin Password: password. Look for Wireless Security, and add a WEP key. Once the router resets, your computer will ask for a key to connect to the network. Just type in what you made the key and you'll be connected.
If you want to lock it so nobody can change the settings, you'll need to do that from the settings page just like last time, except this time look for Administration. Usually it's one of the last tabs. In there you'll see the administrator password. Just change this and you'll have it locked.
Jun 15, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Unable to get laptop too connect wireless ..saying codes /password dont match
You should check the password which you have given for the router. Either you are typing it wrongly or you have forgotten the correct password. Try resetting your password and then try to connect your laptop via that router. Your problem will get solved
Aug 01, 2010 | NetGear WNR2000 Wireless Router
Got a d-link router and somehow i tried to put in a password then after that it locked. how can i unlock it or reset to original setting.
Try looking in the main settings of the router.
Type the IP address of your router into your browser e.g. Internet Explorer, log-in, usually your password is the same as your log-in name.
I have a D-Link router and my Login Name is admin and my password is admin.
Hope this information helps you!
Feb 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
How do i put a lock on my router so only i have it
Normally, routers come with a software wizard that will help you set up your wireless and security settings. If this is not the case, you will need to do it manually.
First, you will need the IP of the router. Sometimes it's listed on the bottom of the device, sometimes it's in the manual, sometimes both. If you still cannot find it, try searching for 'defaul ip for XXXXXXX' where x is your router's modle number.
Then, go into IE (or Firefox, Chrome, Safari etc.) and type the IP into the address bar.
It may ask you for a user name and password. Most times the user name is admin and the password is either admin or there is no password.
Since I don't know your exact modle, you will need to do some searching through the web portal (created by your router that you connected to with the IP) for wireless security settings.
Use something like WPA for your encryption method, or WEP if you don't have WPA. Then just give the router a pass key that you will remember.
Save the changes, and you're done.
Aug 06, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cant lock my wireless router.
Ok, to put a WEP key from our router. You need to configure it, by doing that you need ethernet cable (cat 5). You need to connect your pc to your router using cat5 cable. After you've done that, open your internet explorer/firefox ect., and enter your router's ip address (router ip address can be found in manual or at the back of your router). You will be ask for username and password, just key in if you have one, otherwise just enter the default (mostly, username:admin ; password: none/blank ; depends on manufacturer). After you've done that, go to SETUP menu, and go to Wireless setup you can enable WEP key there, just choose your options. Just try it, I hope it helps you.
Jan 10, 2009 | Zonet ZSR1114WE 802.11g 54Mbps Wireless...
Chanched NAT and got locked out.
Once you have logged into your router, enable the DMZ feature and put in the IP address of your 360.
This will put your 360 outside of the routers firewall and it will give you a full open connection to XBox Live.
Dec 02, 2008 | Belkin (F5D5231-4) Router
Router repair
get one of the tiny little torches you use to thaw locks ( not muck bigger than a propane lighter put a small amount of heat all around the Collete and re-try you'd be surprised
Nov 04, 2008 | Tools & Hardware - Others
Linksys wrt300n wireless router
you could of cracked a solder joint on the mainboard. you probably couldnt see that.
Nov 02, 2007 | Linksys WRT300N Wireless Router
NetGear DG834G Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
