Question about Canon PowerShot A570 IS Digital Camera
I put my SD card backwards (not upside down) in my Canon Powershot A570. I cannot push it in to have it pop up as I should be able to with it turned the right way. Any suggestions. The gold contact s are at the top so I hesitate to try tweezers. .
    Brigadier General:
  • 11,967 Answers
If you want to get it out on your own, you're going to have to use the tweezers. You could wrap some tape around the tips to help avoid scratches.
Posted on Nov 08, 2010
Card locked unlock
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 28, 2013 | Canon PowerShot A570 IS Digital Camera
How do you take out a memory card from canon powershot A570 IS?
Open the card slot cover and push down gently on the edge of the card as if to push it further into the camera. The card will pop out a bit, allowing you to grasp it and pull it out all the way.
Jul 27, 2012 | Canon PowerShot A570 IS Digital Camera
The memory card on my Powershot A570 IS is locked. I have changed batteries @ memory card with no success.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 16, 2010 | Canon PowerShot A570 IS Digital Camera
My Canon PowerShot A570 IS won't turn on. I put new batteries in and checked the memory card. What else can I do?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
May 19, 2010 | Canon PowerShot A570 IS Digital Camera
Which way do the batteries go in and do you have to let it charge when it has not been in use for long time?
yes you must charge your battery for 10 to 12 hrs
and for the way you put your battery in
turn your cam upside down and you will find a door whit a slide button open and fellow the design print in
the plastic for the polarity +/-/+/-
and your done
Mar 04, 2010 | Canon PowerShot A570 IS Digital Camera
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick. When I turn on my camera I get an error message"memory card error" then when i press to view pictures it...
Turn the Canon Powershot A560 over so the bottom is facing up.
Locate the door on the bottom of the camera. The door is labeled "CARD/BATT. OPEN."
Place your thumb on the slider on the door. Push the slider up to unlock the door. Then, slide the door out to open it.
Find the SD card. Inside you will see four batteries and the tip of a small plastic disc. This plastic disc is the SD card.
5
Eject the sd digital memory card. To eject the card, gently push on it and then release the pressure. The SD card will pop out part way. Go ahead and pull out the card.
6
Turn the card so the writing is right-side up. On either the left or right side of the card, you will see a grove with a tiny plastic switch in it. If the switch is at the bottom of the groove, the SD card is locked.
7
Unlock the SD card. Using a fingernail, slide the switch to the top of the groove. The card is now unlocked.
8
Return the SD card to the camera. Place the card in the slot and push down until you hear a click. The card is now successfully reinstalled. Do not worry about inserting the card the wrong way, because it will only fit one way.
Nov 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Card is locked and I don't know how to unlock it
On the card is a little switch that you can push up or down. If the card is currently locked just push the switch in the other direction. This will unlock the card.
Cheers
Please rate!
Sep 28, 2009 | Canon PowerShot A570 IS Digital Camera
Why is it telling me my card is locked?
There is switch on your SD memory card, try to put it on unlock position. If it doesn't solve the problem, you may need to open the camera and check the SD card slot. Refer this solution:
http://www.fixya.com/support/t2234315-its_saying_memory_card_locked_its_not
May 14, 2009 | Canon PowerShot A570 IS Digital Camera
Camera says new batteries are dead
I found out how to fix it. (STEP 1.) Take out all of the batteries. (STEP 2.) Hold down the power button for 30 seconds. (STEP 3.) Put the batteries back in and you should be all set.
Dec 28, 2008 | Canon PowerShot A570 IS Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
80 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
