Question about RCA L32HD32D 32 in. LCD HDTV
Hello, my rca L32hd32hd has a backlight but no picture including no displays such as menu options all that happens is the backlight comes on,dosent look like any swollen caps and all pin connections apperar secure its an 08 set any help before the trash can would be great! thank you for any help
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have a RCA l32hd35d
If you have 24vdc feeding the inverter board, the next signal you need to find is the BL_ON SIGNAL which will turn on the inverter board, it should be 3.3vdc or 5vdc on that pin (pin 12 on CN1 of the inverter board), see picture here:
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj4hv3008001c1.jpg
Posted on Mar 09, 2011
What is the OPC light?
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Feb 04, 2016 | Sharp Aquos Televison & Video
Best quality picture
This is likely a simple settings issue.
A lot of people don't realize that backlight settings can affect the picture.
Go to the menu (press menu on your remote)
The menu will show picture options. Just toy with different settings until you find what you want. It may be on a preset setting that doesn't work. If you are in a bright room, you will need to increase brightness and contrast and perhaps backlight.
Usually an unclear picture is due to the contrast, backlight, and brightness settings being too low. You can also increase sharpness.
I suggest a contrast setting of 70, a brightness setting of 60-80, and a backlight setting of above 80.
Good luck.,
Mar 08, 2014 | Hisense 50 Class LED HDTV - 1080p, 1920x...
Fix display on 27in tv
Hello
You are reporting about the steady CC diplay problem to your set I undersnads and posts this solution. Enter the menu and sur thorugh; come to the Closed Caption menu; select CC display option and turn it to OFF if it is ON. OK.
Jun 21, 2011 | RCA TruFlat 27F520T 27" TV
Remove screensaver from TV
Hello
You are refering about energy saving function I thinks. To energise this function, surf through its menu and come towards energy saver.
This power saving feature reduces the backlight
brightness level. The options are:
OFF-the feature is off and the power consumption
is normal.
LOW-power saving level is low and the backlight
brightness level is lower than normal.
HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
Feb 20, 2011 | Sanyo 42 in. LCD TV
How do i get a full picture on my secnium hd tv?
Hello
To get the picture full screen come to screen aspect ratio settings.
The Screen Format feature allows you to change how the image of a 4:3 picture
is displayed on your 16:9 screen. The options are Normal, Zoom or Stretch. If
your TV receives an image with a 4:3 aspect ratio, the image can be displayed in
one of three ways:
Normal The image of a 4:3 video signal is centered with black bars on the
right and left sides of the screen
To get ito this setting mode
Enter the main menu and go to preferences select the screen format; option-2; and change the settings to get a full picture.
OK.
Feb 03, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Lc32gd8e backlight goes out in middle of a program
This is not a complete solution, but I have found that once the backlight has gone out, I can normally get it back by selecting the "Audio Only" option in the setup menu without turning the set off. This option is really intended for use with radio broadcasts when the picture carries no useful content.
When I press the 'menu' button on the remote and select the right hand most tab, the top option under this tab is 'Audio only'. I select the tab, and then exit from the menu until I need it. When the backlight goes out, I press the following key sequence:
menu, down, ok, right, ok, menu
and the picture reappears. Pressing the menu button opens the menu page at the correct (righthand most) tab. the down highlights the 'audio only' option, and the OK selects this. The right turns the option on (with the backlight working, the picture is removed, but the menu is still displayed). The second OK activates the option. The backlight is turned out. Finally, the second menu key press turns the backlight back on again. This technique has the advantage that the sound continues throughout the sequence, and the recovery of the picture is faster than waiting for the set to boot from a power off condition.
I suspect the problem is caused by an intermittent contact on one of the tubes, possibly as the result of some movement as the tube warms up and expands. (There are 8 tubes in the 32" set.) This causes a safety ciruit to shut down the inverter supplying power to the tubes. Switching off the backlight resets the safety circuit. If I manage to confirm this suspicion, I will write again.
Jun 12, 2009 | Sharp Televison & Video
What is "OPC"? It comes up and goes away.
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
30k gb bla
iPod has backlighting, so you can see the display in low light.
You can configure iPod so the backlight turns on for a set amount of time when you press a button or move the scroll wheel.
To access the backlight settings:
  1. Select Settings > Backlight Timer.
  2. Select a setting from the menu. Options include having the backlight timer:
    • Off
    • Turn off after a period of time between 2 and 20 seconds
    • Always on
A backlight on/off switch can be added to the Main menu by selecting:
Settings > Main Menu > Backlight
Jun 02, 2008 | Apple iPod MA446LL/A MP3 Player
Power refuses to come on
Im not sure really as I've never had that happen but try to unplug set for awhile and plug back in and see if that corrcts your fault. its a possibility that if it dosent work then the set was breaking down at the same time you were turning an option off in the menu but like I said I dont think theres any option that will turn off the set and not let it start back up again UNLESS wait were you watching mission impossible??? nnnaaaaa Just kidding!! LOL Good Luck and please let us know if you find anything.
May 15, 2006 | RCA 27F530T 27" TV
RCA L32HD32D 32 in. LCD HDTV Logo
32 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
