Question about Pioneer VSX-D510 Receiver
No sound display shows speakers off,how do you turn sound back on
  • vwq47 Dec 07, 2008
    Cannot turn speakers On - though relays operate when I press the "Speakers" button. There is no sound from any input, even FM radio. I don't have manual but I DO have the remote. The latter doesn;t seem to help at all ALl other functions appear to operate as one might expect.
    Manuals?
TK YOU FOR ALLOWING ME TO DOWNLOAD THE MANUALS WHICH RESULTED IN MY SOLVING THE SPEAKER TURNED OFF ISSUE.I HAD SPEAKER INDICATOR SET TO SP> SWITCHED OFF INSTEAD OF SP>A ON.
TKS A MIL,
RGDS.
AC.
Posted on Jun 16, 2008
I just bought a used jvc rx9010. it powers up but no sound from any speaker and shows headphone all the time what should a layperson check???
No speakers are selected if just headphone is displayed. Press the speaker button just under the power button. No station is tuned when auto muting is displayed. Hook up an antenna to the receiver or use a different source like a cd player.
Apr 07, 2013 | JVC RX-9010V Receiver
No sound to tv but sound to headset
Are your speakers turn on? Look on the front panel and make sure it shows speakers A on the display. It is very easy to accidentally turn them off with the speakers front panel button.
Mar 12, 2013 | Yamaha RX-V463 Receiver
Radio display says protect. does not emit sound.
Sounds like you have either a short in your speaker wire somewhere, wires touching in the back of the unit or a short inside the stereo itself... Try pulling the radio out and unhooking all of your speakers...Turn unit back on after all speakers are disconected...If unit still shows protect, then radio is bad...If it doesnt, power off and hook up speakers one by one and power it back on till it shows protect again....When it does, the last speaker wire you hooked up has either a crossed wire or the speaker is bad...
Oct 07, 2010 | Kenwood KDC-MP205 CD Player
No sound and video
Video issue:-
Assuming the system power comes up, does the monitor power come on? Most monitors have a status LED on the front bezel that should show green, orange, or blinking if the monitor is powered on. You can hear CRT monitors power on with a gentle sound, though I can't describe it beyond saying it's the sound of a CRT tube warming up. Make sure the monitor is plugged into a good outlet by testing the outlet with a lamp or any other device that will prove beyond a doubt that the outlet is good. Make sure that the power cord is either permanently attached at the monitor end or that it is seated fully in the socket, since partial cord insertion is the most common failure for monitors with detachable cords.
LCD displays don't make any sound when you turn them on, but they don't have a simple power cord, either. Older LCD monitors are usually powered by an external transformer, which in turn is powered from a regular AC outlet. If the LCD display doesn't show any signs of life, make sure that the cords into and out of the transformer are fully seated. Some transformers are equipped with a status LED to show when they are operating. The power connection to the LCD display is often awkward to inspect, recessed into the back of the display. The important thing is to make sure it is started correctly, then seated all the way.
Sound issue:-
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 06, 2010 | Computers & Internet
Surrond sound not working
it all depends what digital mode you use ,yes in Pro Logic mode on the display it shows only 1 S but if you try the balance for the SL-SR you will hear the difference .
Feb 03, 2009 | Sony STR-DE675 Receiver
No Sound
when the amp is turned on does the unit make a clicking sound a few seconds after the display lights up.
if not the amp's is not happy with it's power or could have a speaker short. Check the display for a fault warning.
Otherwise check you speaker connections.
confirm that and A and B main speaker buttons are correct.
Try some headphones, if you get sound out of the headphone things might not be too bad, if nothing is output remove all your cables and try again.
Yes I know that can be nasty, so label all the cables first.
Jan 21, 2008 | Yamaha RX-V1500 Receiver
Display shows only L and R speakers.
I think you need a digital coaxial wire instead of the composite ones
Nov 19, 2007 | Yamaha HTR-5630 Receiver
Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Feb 09, 2007 | Amphion Mediaworks T-365 System
Pioneer VSX-D510 Receiver Logo
302 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
