Question about Philips GoGear SA2625/37 MP3 Player
When I connect my device in my pc it says "file system error" and I can't do nothing... Can you help me?
3 Suggested Answers
at_some
SOURCE: Firmware won't update; Player won't turn on or show up on PC
well done XP! device repaired :)
I'm so happy I didn't sell my travel notebook,
good enough for running XP slowly... very slowly.
I will left more space now than last time. Why I didn't
thought that some kilobytes aren't enough for operating.
Posted on Aug 26, 2009
  • 50 Answers
SOURCE: I formatted my player. Than
This device is only capable of playing MP3 and WMA files. Make sure that the files are in a format that the system can recognize. If that doesn't work, use the software for the device to make sure the firmware is up to date, and not corrupted, and reload the files. Hope this helps!
Posted on Feb 28, 2011
Unauthorized device has been detected
Error Message: Error 003 Unauthorized Device Has Been Detected
Situation:
System is displaying error message: Error 003 Unauthorized Device Has Been Detected
Information:
This error code indicates the region the system was manufactured for is not compatible with the Wii System Menu update. This incompatibility has made the system unplayable and it cannot be repaired. Nintendo is not able to provide support for these systems.
It has been modified so you will have to buy a new console sorry.
Oct 22, 2012 | Nintendo Wii Console
"Error Message: 104-Unsupported wireless network
Go to the network connection or network and internet connection in the control panel. The pc maybe picking up wireless connection from other devices around you. You can go there and remove them.
Jun 28, 2011 | HP Compaq Presario V2000 Notebook
Hey there. I have a problem with an external harddrive. "My Passport Essential". When I connect it to my compute sometimes nothing happens and sometimes "Local Disk (E:)" shows up in my...
The problem might be a loose connection or bad configuration file (an autostart ini file that makes the hard-drive do certain things when plugged in) in the root folder of your hard drive. Are you able to connect to it sometime or it doesn't work at all? If you can read it, try backing up all your data and format the hard drive and copy back the backup again. But remember to copy only the needed files and not the system or ini files.
May 06, 2011 | Western Digital My Passport Essential...
Hello, the problem that I have with my SanDisk 2 GB MP3 player is that now, whenever I try to put songs on it, I get a message that "the device has stopped responding" or "the device does...
Try and reset the player first, If this does not fix the problem, Click this link to down load the Sandisk updater program to run a firmware update...Updater... Resetting the device: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Next time you need to delete files heres how. --
There are two ways to delete files on your Sansa player. You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device 1. In playback mode, press the Submenu button. 2. Select Delete.
METHOD 2 - Delete files using a PC For all other Sansa players: 1. Connect your device to the PC. 2. Select Open device to view files using Windows Explorer on initial connection. 3. Locate the folder where your files are stored. 4. Click to select the files you want deleted and delete the files.
NOTE: If songs still exist after deleting, you may need to switch USB modes from MTP to MSC or vice versa. See this tip HERE
Capacity issue This error occurs when a Sansa player is almost filled to capacity. A Sansa player can NOT be filled to full capacity. (i.e. you can't put 2GB worth of songs into a 2GB player)
The player needs the extra capacity to create and maintain a "database", a database holds all the information such as playlists, recordings, song information, etc. The larger the amount of songs, the larger the database gets.
To resolve this capacity issue, you have to delete contents on your Sansa player using a PC.
STEP 1 - Delete files on your player 1. See first note on how to delete files on your Sansa player using a PC.
FAT corruption This error also occurs when there's a file system corruption in your Sansa player.
To resolve this issue, run error-checking to fix errors in your device using a PC
STEP 1 - Connect the Sansa player to the PC in MSC mode
STEP 2 - Run Error-checking to check and fix errors 1. Double-click on My Computer (Computer for Windows Vista). 2. Right-click on the drive letter associated with your Sansa player and select Properties. 3. Click the Tools tab and select Check Now. 4. Click both check boxes under Check disk options. 5. Click Start
If an error occurs while plugging in the player to the PC and some files are missing in the player, the database might be corrupted. To resolve this, you will need to format your player.
NOTE: Formatting will delete all files in the device. Your data (music, photos etc) is NOT recoverable.
Nov 16, 2010 | SanDisk Sansa e260 MP3 Player
JVM Error 102 on BB7290
From a very trusted forum, I quote:
102 Invalid code in filesystem
The system has checked the .COD files in the handheld for modification, and determined that there is a problem with one or more .COD files. If all loads fail, it could indicate a build process error where there was a problem signing the codfiles. If some user action to the device caused this problem, the reset cycle will be continuous since the code in the filesystem has been corrupted. The only recovery method is to wipe the device and restore a new system.
Aug 06, 2009 | Computers & Internet
Tom tom go 300 ''unable to store settings'' ''file access error'
You might have the switch on SD card set to "read only" , This would stop your tomtom being able to write to the SD card ... hence , " unable to store settings " message . .... OR ... the folder where your tomtom wants to store the settings is corrupted ( on your SD card ) so it can't store them.... or similarly , the file is corrupted on the SD card ( maybe the card is damaged ) so the existing file cannot be overwritten . Check out all these possibilities before suspecting any hardware fault on your tomtom ..... GOOD LUCK
Nov 24, 2008 | Tomtom GO 300 GPS Receiver
Philips GoGear SA2625/37  MP3 Player Logo
15 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
