Question about Sherwood Audio Players & Recorders
Does the sherwood ra 1140 receiver have a phono connection ?
    President:
  • 2,992 Answers
This photo shows a front-panel PHONO button, so I'd say that it does have a phono input
Posted on Nov 07, 2010
  • dthd2 Dec 04, 2010
    The front panel jack is for headphones. The RA-1140 has right and left jacks on the back for phono, cd, and video/aux.
  • Dec 07, 2010
    Notice my replay. It did NOT say a front-panel phone jack, it said a front panel phono BUTTON. I was implying that if the receiver has a phono button so you can select that as the source, it must also have a phono input. I guess I was too subtle and should have just said YES IT DOES. I guess I give some people too much credit for being able to figure things out.
Phono input only plays one speaker and receiver shuts down after playing record for a few minutes
are you using a phonograph with a built-in preamp? If so, then you need to hook it up to a different input. Phono input is only for non-amplifier phonographs, otherwise you will over-drive the amp.
Oct 10, 2015 | Sherwood RX-4109 Stereo Receiver Black
Is the Phono output on the RX4109 considered a preamp output in to a Power Amp?
The phono connection is an INPUT and it is a low impedance circuit. It is easily overdriven because the signal that goes into it is very small. You plug a record player into it. Any pre-amp connections on an audio device are in place after equalizer controls. There are no pre-amp connections on the Sherwood.
Sep 13, 2014 | Sherwood RX-4109 Stereo Receiver Black
Sherwood ra 1140
You may have a dry solder joints.
Feb 11, 2014 | Audio Players & Recorders
What is a compatible turntable for my Sherwood rx-4109 receiver?
many decks have pre amps or need preamps. hence the reason why you have distorted sound i would guess. you need the opposite of what you used. What record deck did you try?
Jan 06, 2013 | Sherwood New-RX-4109 STEREO RECEIVER WITH...
Can I download manual for RX 4109?
Hi,here is the link for your download...
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
http://www.sherwoodusa.com/prod_rx4109.html
RX-4109 Remote Controlled Stereo Receiver with Phono Section
Unlike the budget stereo receivers now flooding the entry-level price points at dealers across the country, the Sherwood RX-4109 is designed and built in-house with the same quality and attention to detail we have been bringing to our audio gear for the last 50 years.
With 105 Watts RMS per channel, phono section, binding posts, a versatile remote control and switching for two pairs of loudspeakers, the only thing that bespeaks the word "budget" about the RX-4109 is its modest cost.
MSRP 179.95
Jun 22, 2011 | Sherwood RX-4109
Sherwood RX-5502 receiver - get no sound.. checked polarity - OK... replaced speaker wire - OK... checked speakers on another device - OK.... tried phono and tuner and cd player - no sound with any........
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
Jul 11, 2010 | Sherwood RX-5502 Receiver
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Sherwood RX 4105 no input for a turn table
Check for a line level switch on the turn table, it may be under the turn table itself lift the rubber mat and spin the table by hand, it may not have one or it could be on the back.
You can buy a phono amp that will boost the phono signal. Check at Radio Shack or google it.
Jan 31, 2009 | Sherwood RX-4105 Receiver
FM Tuner in Sherwood RX-4105 stopped working
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Dec 02, 2008 | Sherwood RX-4105 Receiver
PS-T3 connection to Sherwood 4105 Receiver
You need a phono stage (phono amp) between the turntable and receiver to boost the lower signal from the turntable. If your receiver has phono inputs, use those as there will be a built-in phono stage.
Oct 14, 2008 | Kenwood KD-291RC Turntable
495 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
