Question about AEG Lavamat 88840 Front Load Washer
Hi I have a AEG Lavamat 748000 I have taken out the rubber coller to give a good clean as its been leaving markes on washing.Now all clean but I cant seem to put it back on and get the inner spring band back on.I am doing it all from the door. Please help as iam getting real ear ache thanks max
Timon90
  • 126 Answers
SOURCE: How to re-fit front rubber seal on Lavamat
The seal is mounted to the outertub with a big spring, an on the frint with a plastic ring. Not very easy.
Posted on Jan 24, 2008
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Feb 10, 2009 | AEG L12700ViT Front Load Washer / Dryer
Detergent drawer does not empty detergent
hi! remove your powder draw, it should just pull out with a wiggle,give it a good clean in hot water, before you put it back give the draw hola a god clean with a bottle brush and hot water! good luck
Dec 20, 2008 | AEG Lavamat W1050 Front Load Washer
Have an AEG Lavamat 88800 washing machine. Problem is that getting a build of a brown sticky residue in the rubber seal araound the door, which then gets on the clothes being washed! 9it is not mould - I...
You are using a cleansing agent that has no biological cleaning agents so it does not clean off all the organic debris.
All very well for those with sensitive skin but not for the machine.
Try lemon juice to de grease the boot.
Aug 03, 2017 | AEG Washing Machines
Lavamat 86800 stop the washing cycle after few seconds without any error code
Hi - did you ever find a solution to the problem? My 12 year machine now showing the same issue.
Oct 11, 2008 | AEG L86800 Front Load Washer
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Aug 03, 2008 | Washing Machines
AEG Lavamat 1000
hi
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Jan 20, 2008 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat w1450 electronic.
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Nov 12, 2007 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
