Question about HP DVD±RW Burner
I removed my old cd rom that came with the computer and put the new one in.when i put the cd in that came with the new cd rom it said installation was unsuccessful.i bought the hp dvd1270i
    President:
  • 2,571 Answers
Usually the software that comes with a new dvd/cd burner is just burning software (nero or roxio).
Your drive is just plug and play and windows has all the drivers that is needed.
I would uninstall the software you installed and try it with free software like IMGburn or CDburnerXP
Posted on Nov 07, 2010
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
Need to install second cd driver in desktop computer
It would be much simpler to remove your current CD-ROM drive, and install a CD/DVD-reader-writer combination drive.
1. Turn the computer off, and disconnect the AC power-cord.
2. Remove the side-panels from the case.
3. Disconnect the "power" and "data" cables from the back of the CD-ROM.
4. Remove the screws holding the current CD-ROM in position.
5. Slide the CD-ROM out the "front" of the case.
6. Slide the new device into place, until the face is "flush" with the front of the case.
7. Screw the device into position.
8. Connect the data and power cables.
9. Reconnect the AC power.
Windows will "find new hardware", and will adapt itself.
Dec 10, 2009 | Acer Computers & Internet
WHAT IS THERE TO DO WHEN INSTALLING A NEW HARD DRIVE TO MY LAPTOP
1. Remove the old drive, noting whether it has a SATA interface or an IDE interface.
2. Take the old drive to a computer-store, to buy a new drive with the same style of connectors.
3. Connect the new drive.
4. Find the "System Restore" CD-ROM(s) that were shipped with your laptop.
5. Turn the computer on.
6. Put the first of those CD-ROMs into the computer.
7. Force the computer to boot from the CD-ROMs.
8. Reinstall Windows.
9. Install anti-virus software.
10. Access http://WindowsUpdate.microsoft.com to get all the latest security-updates for Windows. You may have to access it MORE than once, in order to get "updates-for-the-updates".
Oct 10, 2009 | Acer Aspire 5100 Notebook
Need to find out how to install my memorex double layer 16x
Ok here is what you need to do. Open the box that the driver came in and also the side panel of your computer. Remove the cables that are attached to the current CD-ROM drive and if you need to unscrew the screws that are holding the CD-ROM drive in place which you'll need a phillips screw driver for. Remove the old CD-ROM and put in the new one and reconnect the cables to the new one. If an installation disk came with it then put that in the CD-ROM drive and install whatever is on that disk. Afterwards you should be ready to go. If you need anything else please let me know!
Apr 05, 2009 | Computers & Internet
How to replace CD-ROM in Medion MD40566
Generally what you will need to do is first open the computer case. Then you will see 2 screws on each side of the CD-Rom Drive. You will need to remove these screws. Now you should be able to slide the CD-ROM forward away from the front of the case. Before you completely remove it you will need to remove the cables at the back of the CD-ROM before removing them note the position of them. Now that the CD-ROM is removed bring it to the store and ask the associate for the correct replacement. Once you bring the replacement home installation is reverse of the listed procedure. One thing to not is the position of the Jumper on Slave, Master, or Cable Select. This will be explained on the instructions that come with the new drive. Whatever the jumper setting is on the old drive make sure it is set the same on the new drive. Once this is done turn the computer on and you should be all set. Good luck and keep me posted.
Thanks - Tech101
Jun 24, 2008 | Medion Computers & Internet
A DVD-ROM problem
Find a technician who can do it for you - or if you are conversant with computers you get an eternal dvd rom Drive and use it. Have you tried the floppy drive if your computer has any? or the flash disk?
please try one these options.
Dec 31, 2007 | Toshiba Satellite A60 Notebook
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Replacing cd-rom
u need open the cabinet and there should be a serew and remove it and connect teh new one and make sure teh power and date cable the red side of teh power as well as the red side on teh data cable should face same side and start the pc>and put the cd and install soft ware and start using teh dvd and cd>rate me solved if its helps thx
Nov 16, 2007 | HP Compaq dc5100 PC Desktop
SH-S182 installation
before anything else.. your computer must not be plugged in
have some screw drivers ready
open the case
remove the connections of your old cd/dvd-rom
remove the screws
remove the drive from the bay
replace it with your new dvd writer
replace the connections and the screws
put everything else back
then turn on your system :D
Nov 02, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
HP  DVD±RW Burner Logo
128 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
