Question about Goodman GMS90703BXA Heater
Have agoodmangds80703ana i opened the door to bypass the limit switch also jumped out the door switch now i have no light am i missing something
  • 1 more comment
  • ncc630 Nov 07, 2010
    have power thru the door switch also have 120 and 24 volts thru the trans former no power to the r terminal were the t stat wires are
    the fuse ohms good
    have no power to either side of the fuse should i have 24 volts to it
    President:
  • 1,891 Answers
Double ck your door sw and on somel models there is two door sw in series .. not sure why your jumping these but is sounds like you have been there before .. if door is bypassed it also may cause a air flow problem because you are not drawing air properly with door off . . and the hi limit is for an over heating problem . soo re ckk wires and air flow and it should go .. mm
Posted on Nov 08, 2010
  • Goodman Master
  • 43,501 Answers
Either you have killed the transformer or tripped the circuit breaker...
Do you have power on either side of the door switch???
Does the transformer have power?
Is the fuse blown on the circuit board?
Do you have 24v on the R terminal to the t-stat?
You have a power problem... you just have to trace it through and find out where the problem is...
To do this you will need to have a voltage meter to check the circuits and know how to use it properly...
heatman101
Posted on Nov 07, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 07, 2010
    That narrows it down to something at the board... I would change that fuse....is there power to one side of the fuse???
    If so and then power through the fuse then it has to be the board...
    follow the electric trail.... :-0
    heatman101
No start/No heat condition!
Suggestions
1. diconect power
2.check continuity of door sw
3.if able to access motor terminals check for open windings
and check to motor case for short to terminals
4.check heater terminals for open circuit
When you bypassed the start sw was there any sound at
all from the motor?
Nov 18, 2007 | Dryers
Garage door opener
Does the travel direction make a difference? There is typically upward / downward force adjustments. Also when it stops will it start again immediately if you activate it.
Mar 31, 2017 | Building Materials
I have a Toyota Highlander 2005 Limited. I have two problems on 1. the front right & both rear windows won't resp ond on there own switch but all work from the master switch on the drivers door. Fuses are...
Have you checked each individual door switch
for voltage? If there is voltage and a good ground try jumping the switch with a bypass wire to see if the window responds. It could be a bad master control switch which you can bypass to check to see if its working properly. Drivers door switch module. They are known to be a problem. Hope this helps.
Oct 16, 2013 | Cars & Trucks
I have fridgidaire dryer and when I push the start button it just makes a buzzing noise but does not start
Unplug the dryer or disconnect power then remove the two screws securing the top panel to the rear and slide the panel backwards and off.
Behind the drum is the thermal limiter which is wired in series with the motor.
Check the continuity of the thermal limiter and if it reads open, replace it including the high-limit thermostat located on the heater housing (also shown in the picture above). Bypass the thermal limiter for troubleshooting purposes by joining the wires together and insulating it properly. If the dryer starts and runs properly with this setup, the thermal limiter is indeed open. If the dryer still does not start, jump a wire between the COM and NO terminals of the door switch. The dryer should start with the thermal limiter and door switch bypassed, otherwise bypass the motor relay on the control board. Replace control board if the dryer starts with the three bypassed, otherwise the motor is the one at fault and needs to be replaced.
Aug 21, 2011 | Frigidaire Electric Dryer
Trying to wire an old garage door motor to run without door controls. All I need help with is knowing how to bypass the circuit board
There really is no way to bypass the circuit board on this. There should be two terminals on the logic board you can wire the button to, although without limits it will run until you hit the button again and depending on the brand might reverse. Thanks BB
Jan 17, 2010 | liftmaster Chamberlain Garage Door Opener...
After the door is fully open, the motor stalls when closing. It trys to continue to open instead of close and the screw drive carrage jams against the "open" end and stalls. I have to unplug it to get it...
It sounds like you have a broken or missing "upper limit switch". There is one for the down limit and should be one for the upper limit. If it is defective or missing the openers 'brain' will not tell the motor to reverse direction.
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Nov 06, 2009 | Goodman GDS80904BNA Open Flame Heater
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Goodman GMS90703BXA Heater Logo
19 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
