Question about DISH Network 311 DTV Receiver
My 311 is connected to a dish 100.2. It has worked fine for a while. A few days ago it lost signal. I ran a swith check and it said there was fewer satilites than normal. Well I checked out the dish and it is receving the proper satilitesand is sending signal. I also took the 311 and hooked it up to a dish 500system,it worked fine. What is going on? Thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Firerun1,
When you get the message 836, found fewer satellites than previously detected, it usually indicates a problem with a component between the dish and receiver. Normally a tech needs to be sent out to find the problem and to fix it.
Depending on the number of receivers you have active on your account, you may have a loose cable to that receiver if other receivers are working okay. If you have a switch between the dish and receiver, a port on the switch may be bad. If this is occurring on all your receivers, you'll need to call Customer Service to setup a Tech visit.
I hope this helps.
Ray Calo
DISH Network
Posted on Jan 07, 2011
My 311 receiver worked fine for years with no problems. It has always sat up on a shelf where the connecting cables wont be touched. Recently all I get out of it is a 015 message and it makes no progress...
Have you tried resetting the unit. Open the door to the activation card. Press and hold the small red button. If this does not correct it is probably the receiver. Also if the dish is near trees, new tree growth could be blocking your signal.
Sep 04, 2013 | DISH Network 311 DTV Receiver
Receiver lost signal, cannot aquair
It sounds like the dish may be mis-pointed since it's not recognizing all the satellites. The next step for this would be to send a technician out to get everything fixed.
If you would like any assistance setting up a technician, just send me an email at thomas.faust@dish.com and I would be happy to help.
Tommy Faust
DISH Social Media Representative
Jul 01, 2012 | DISH Network DVR-625 DTV Receiver /...
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
Hello, i have dream box DM 800 HD PVR
Hardware. Check the power source, the 18v is used only for the LNB.
Feb 12, 2010 | RCA DISH Network(r) 311 Satellite System
Satellite signal "lost" after digital changeover
RG6 is the standard, as opposed to RG59 cable. The new cable would not cause the problem to start or continue.
Who was the tech who came out to your home? A Dish Network tech? And left the site with it still not working?
Resetting, unplugging the receiver, and having all those parts replaced... yeah that almost sums up everything that could be done with the exception of replacing the receiver itself.
It's rediculous that you have been dealing with this problem THAT long. Call Dish Network, give them a recap, and tell them your going to cancel and go with DirecTV if they don't fix the problem. Then speak to a supervisor if you get a rep that doesn't seem to care.
All else fails, go Direct. Better customer service, more HD.... that's what I have!
Jun 14, 2009 | DISH Network 311 DTV Receiver
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
Dish 311 won't detect switches
dishnetwork is kind of tricky on the detect switch thing. sometimes if you are having troubles on just one receiver you have to run detect switch over and over again, sometimes as much as maybe 20 or 30 times. if it still doesn't work, hope you have a service plan so they will send you another unit to switch out. also try a different LNB ( low noise block downconverter) and check switch a few times. i know that sounds kind of stupid, but it works sometimes.
Feb 17, 2008 | RCA DISH Network(r) 311 Satellite System
Dish 500 and receiver 311
100% yes. that's what it is supposed to be connected to.
Jan 27, 2008 | RCA DISH Network(r) 311 Satellite System
Dish network 119
you cannot satellite sginal from a splitter you will need dp 34 switch or quad LNBF DP HOPE THIS HELPS.
Jan 12, 2008 | RCA DISH Network(r) 311 Satellite System
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
DISH Network 311 DTV Receiver Logo
228 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
