Question about Sony KDL60EX700 60 in. TV
We have a SONY KDL60Ex700 TV and cannot access any program data using the TV Guide feature. We use an over-the-air antenna, the TV clock is set correctly, have tried using the zip code for a nearby large city as region, but still when the Guide button is pressed, the TV Guide screen appears, all of the channels are listed, but NO DATA is what appears next to the channel listings.
  • 10,421 Answers
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
My sony led tv model # kdl60ex700 blinks 6 times my sonny TV blink 6 times model # KDL-60EX700. What is wrong
I need more information like:
When it is turned on,
Turning off,
Connecting to something,
To close to the wall......Things like this to better you with your problem.
Aug 27, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
Can i set the clock manually ?
Yes, you can. There are different ways of going about it. There's an ongoing thread in the AVS Forum specifically with these Sony DHG units, now that the TV Guide System (ROVI) has been discontinued - which these Sony units relied on the Guide data to set the clock:
This thread is very, very long. The following link starts in Nov 2012 where the discussion picks up about ROVI stopping the TVGOS except via the Internet:
http://www.avsforum.com/t/537711/sony-dhg-hdd250-500-official-thread/25260#post_22550572
I am User member CleCakYngMfd in this forum.
Feb 04, 2013 | Sony DHG-HDD500 400-Hours Video Recorder
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
My on screen TV guide no longer works, and my TV keeps losing time (between 10 and 20 minutes). I'm not sure how to fix this. Is this a hardware issue or a settings issue? Has someone else had prior...
Do you have cable TV? Many Cable TV companies have recently (over the last year or two) quit sending TV Guide data. You can get it through an external antenna connected to the TV's antenna input if you are within range of an ABC or NBC and a PBS affiliate for the clock auto set.
But if you still have TV Guide service, some of these have failed circuit boards for the TV Guide, ( usually shows a complete black screen when you turn it on or hit guide button.
Apr 13, 2010 | LG 50PX4DR 50 in. Plasma TV
Everything on the TV works EXCEPT live TV.
Please clarify a few things. Are you using cable TV, satellite TV or a TV antenna? If cable, are you using a set top box (and is it powered on) or does the TV convert the cable info. If satellite, is the set top box powered on? If off the air (antenna TV), can the TV receive the new digital signals and if not, do you have a digital converter box between the antenna and the TV?
Jun 04, 2009 | Toshiba REGZA 47HL167 TV
My over the air channel list program times are 1 hour behind.
I've just sorted the problem on my set , Samsung UE40S6300UXXU, L.E.D.
Enter, "menu"/system//time/clock/......make sure "clock mode" is set to "Auto" and scroll down to "Time Zone" make sure time zone is set to manual, go down to "GMT" and set it to GMT+1 and the job is done. Hope this helps
Mar 14, 2009 | Samsung LN46A630 LCD TV
TV Guide System not working
In order to receive the TV's Guide system, the cable should be connected directly to the TV instead of the cable box if you are still using it.
How do you have the cable box connected to the TV?
Jan 24, 2009 | Pioneer PDP-5060HD 50 in. Plasma...
Can't change the clock time
Best Solution posted Nov 6, 2008, by Guest -- worked for me. Wondering what the DST is? -- Daylight Savings Time. There will be a button at the bottom right in the date OFF. Apparently the TV Guide programing does not work that well, especially with the new Digital boxes now need to receive over the air TV and the TV Guide programing never worked with Satellite TV. Wil this feature ever be up dated? I doubt it. It would be nice to have the digital box and your dvr cycled together.
Nov 03, 2008 | Panasonic DMR-E85H DVD Recorder
Sony KDL60EX700 60 in. TV Logo
288 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
