Check if the printer services is enabled. Click start, run, enter services.msc and press enter. Look for Print Spooler. Right click and select properties, In the general tab, select automatic as start up type and start the service. See if it works and let me know.
you need to go on google & then .
right this test my sound card & repair.
microsoft will tell you that you sound card used by something else/
microsoft will restore it for you
using the bluetooth software on your computer, do not tell the computer you are looking for a bluetooth printer, instead, use search for all devices, then the printer will show-up and select it.
printing via bluetooth does not require a driver (it's just like printing from your cellphone)
you'll see the Drive Capacity.. C:\ driver, if you want use the majic partistion8 increase ur c:\ drive capacity.. ofter you'll installed that software it will work..
get rid of vista? that is my suggestion, but if it came with the vista install cd, try running the system restore from the disk. note: YOUR PROGRAMS MAY DISAPPEAR IF YOU DO THIS!!! if you have an xp install/restore disk, you could try installing it onto your computer, but it won't look like vista. to get the vista feel back, download vitamiser from www.softpedia.com
You can go back to Vista. Should be loaded on the D section of the hard drive.
On startup press F10 and go through recoery and allow it to relaod Vista to its default configuration.
It may not work at all on Vista, many programs and hardware do not. (scanners and printers etc. -- no new drivers)
Is there any way to update the program?
Go to the company website, check for Vista compatibility.
You may have to purchase an updated program.
