Question about Roomba Robotic Floor Bagless Vacuum
Roomba doing circles for 30 seconds, and turning off w/ warning light coming on. Seems that it thinks it is constantly hitting a wall or something...
3 Suggested Answers
SOURCE: Roomba turning off after 30 sec.
I was having the same problem. Roomba would run for 30 seconds and then stop. I tried everything -- then I took the small rubber brush out and removed the small nut at the end. It was packed with dust to the point that it could not turn easily. I cleaned it out and now it is working like a champ. I think the automatic shut down was just a sign that there was too much strain to turn the brushes.
Posted on May 30, 2008
  • 66 Answers
SOURCE: The Roomba goes around in circles. If it
Are you sure it is 10 beeps ?
look in your user's manual, the beeps code is there with some
suggestions how to solve it
Have fun
Avi
Posted on Apr 12, 2010
Roomba just turns in circles what could be wrong
What to do when the Roomba just goes in circles ' All about Roomba ...
https://roombafan.wordpress.com/2015/05/17/roomba-just-goes-in-circles/
May 17, 2015 - Single beep - Roomba is stuck or wheel is hanging down; you need to move your Rhoomba to a new location or check the wheels. Two beeps - this happens when the main brushes become immovable, so you need to check the brushes. Six beeps - the likely cause is a dirty cliff sensor or the robot is stuck on a cliff.
Roomba is backing up and circling. - Find Answers ' iRobot Customer ...
https://homesupport.irobot.com/app/answers/.../roomba-is-backing-up-and-circling. If Roomba backs up or spins in circles, run Roomba in an open area with no obstacles present for 2 minutes to determine if the robot will stop with an error ...
SOLVED: The Roomba just goes in circles, how do I fix this ...
https://www.ifixit.com/.../The+Roomba+just+goes+in+circles%2C+how+do+I+fix+this Oct 23, 2016 - Dirt and debris can cover the sensors and make the roomba believe it is ... When my Roomba turns on, it will only spin around in circles and ... Won't go straight; not circle of *****
May 30, 2016
Vacuum will not go straight
May 7, 2013
SOLVED: roomba 560 got wet and now it doesnt go forward ...
May 15, 2012
SOLVED: When I turn my Roomba on, it doesn't go forward ...
Apr. 25, 2011
More results from www.ifixit.com
iRobot Roomba circle dance - "fix" - YouTube
? 5:37
https://www.youtube.com/watch?v=sN03AWr1VAk Jan 21, 2008 - Uploaded by Scubaholic
Didn't feel like open my roomba at 10pm, so I just sprayed it with some canned air around the wheels and ...
Help! My Roomba goes in circles! - Robotic Vacs
https://robotic-vacs.com/2016/03/03/help-my-roomba-goes-in-circles/ Mar 3, 2016 - What to do if your Roomba just goes in circles. Roomba goes in circles. No, your Roomba doesn't have a mind of it's own, nor is it tipsy from ...
May 20, 2018 | Roomba Vacuums
Roomba starts out in a circle goes wider and wider then all at once goes in circles.
when it starts doing that hit the start button again then wait a few sec.
Jul 19, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba stutters on one wheel causing it to quit
Try setting the Roomba on the floor, powering it up, pressing down hard on the front, just above the front wheel, and hitting "clean" or "spot." My Roomba had the same problem, and this seems to do the trick for it. I think it has something to do with the Roomba thinking the front wheel is extended (which would indicate a cliff) even though it's really not.
If this doesn't work, you might try pressing down over whichever wheel doesn't turn when you turn the Roomba on.
Mar 22, 2010 | iRobot 4150 Roomba Vacuum
Roomba going in circles
Roomba going in circles. Called irobot and if reseting it (by taking out the battery, unplugging it from the charger, and holding down the power button for 30 seconds), didn't work, turn the roomba over, take a compressor and blow air into the front. Maybe a shop vac would also work. We cleaned out the whole thing while we were at it. And now it works just fine. The tech person at irobot was very helpful.
Mar 14, 2010 | iRobot 530 Roomba Vacuuming Robot, White...
Roomba 560 goes in circles. appears lost
You have a locked wheel switch that needs to be cleared. You will need to remove the top of your roomba and find which wheel switch is clogged and clear it.
Mar 14, 2010 | iRobot Roomba 560 Robotic Vacuum
Turns in circles, acts like it hits a virtual wall then stops
Reboot is probably not your solution. Your Roomba will react to invisible signals or 'interference' from other electrical appliances as well as the invisible wall boxes. You can clearly see how this happens when a Roomba gets near your computer or other device that is on. Also, the Roomba will go in circles when the dirt chamber is full or it thinks it's full. Try a thorough clean of all major parts including the brushes. Sometimes this activity will occur when the brushes get snarled on thread or carpet fibers.
Oct 09, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
My Roomba 560 has started to run in small steps as if it constantly meets an obstacle and turns around in a very small circle. It advances slightly, backs slightly and turns and then does this again and...
It probably does think its met an obstacle. It could be the bump sensor switch remains pressed, one of the 4 cliff sensors on the front is dirty, or one of the 3 wheel drop sensors (left right and caster) is alarmed. Clean the sensors and your problem may resolve.
Oct 04, 2009 | iRobot Roomba 560 Robotic Vacuum
Backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Jul 23, 2009 | iRobot Roomba 500 Series Virtual Wall...
Red sensor
If your Roomba's red "check robot" light comes on, the Roomba should also give a hi-lo warning tone, then a number of beeps. Check the number of beeps with the chart toward the end of your manual-- it should tell you what to do.
May 29, 2009 | iRobot Roomba 560 Robotic Vacuum
IRobot Roomba Discovery not moving across room.
I had the same kind of problem with my model 400 today...after starting it and having it go in a circle for 30 seconds or so it would finally run into something and then back up a few inches, turn, then go forward a few inches, then back up a few inches, turn, then go forward a few inches, etc., etc.. I tried cleaning off the four pairs of sensors under the bumper and blowing out various things underneath (by mouth since I didn't have any canned compressed air). It didn't really help. It then occurred to me that I had a leaf blower! I put the Roomba upside down on the grass, put the leaf blower on high, and blew at it from all directions and up close. More dust came out than I thought would. It has been running normally now for the last 45 minutes.
Sep 26, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba Robotic Floor Bagless Vacuum Logo
Top Roomba Vacuums Experts
Marvin
Marvin
NOEL
NOEL
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
