Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
My printer says make sure printer queue is online. Fine but how?
  • 132 Answers
Open up a command prompt (Start -> Run -> type "cmd" -> Enter)
type "net start spooler" -> Enter
Posted on Nov 07, 2010
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
Dell v515 printer
Several immediate things come to mind; check to make sure that the printer drivers are up-to-date; there maybe a possibility of an IRQ conflict; check to make sure that the printer is set as the default printer in control panel; make sure that the printer you want to print from in the <file>, <print> menus screen is selected and not a virtual one. Absent more info like OS and how your printer is connected to your computer (e.g., is it through a serial cable, then make sure com port is active in BIOS and is checked off in the properties menu [control panel, printer, properties, port tab]; or are you using an LPT-printer port or USB connection- make the same check. Sorry that I can't be more specific without additional info.
Nov 22, 2013 | Office Equipment & Supplies
Canon MF4690 offline
double click on printer print queue opens make sure all print job is cancled
the click file and set printer online cabel must beconnected.Left click on printer and make sure you select the corect printer port or above will not work
Mar 13, 2012 | Canon imageCLASS MF4690 Multifunction...
Print driver (2228C PCL 5C) shows printer queue offline. How can I bring it back online? I have rebooted the printer. There dosen't appear to be an option on the print queue when going in as admin on...
Remove the data cable from the back or size of the printer. Turn the printer on and let it cycle. Then plug back in the data cable. It should show a green light by the cable if you are reconnected.
May 12, 2011 | Ricoh Aficio 2228C Copier
I keep getting message that my Canon Printer Pixma iP3000 'is offline'. How do I get it to be 'online' so it can proceed to print the 2 documenys on the printing queue?
Here's the steps in order for you to get your printer ONLINE and be able to print.
1. Click on your START menu
2. SETTINGS / Printers and FAXES or via COTNROL PANEL, printers and faxes
3. RIGHT click on your printer
4. Make sure "Use Printer Offline" is NOT ticked, if it is, UNtick it
Your printer should respond immediately if there are documents on queue for printing and should print it out.
Hope this helps!
Good Luck!
Mar 14, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Computer says "queue is offline"
Check:
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
Also on the computer:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 21, 2011 | Computers & Internet
Printer in queue, need to print
It could be a print job that has stalled.
Open the print queue (on the taskbar by the system clock)
and cancel all the documents that are there ,then reprint and see what happens.
Also make sure the printer is plugged in and online.
Apr 21, 2009 | Lexmark X1240 All-In-One InkJet Printer
HP photosmart C3180 stops printing
Posted by JACOB I understand that you are unable to print and when ever u try to print the jobs stuck in queue... When we right click on the icon if we see a option use printer online this shows that the printer is offline, if we see a option use printer offline in the list then this shows that the printer is online status. To resolve the issue we have to first clear the job in queue. Open the printer folder and then double click on the HP printer icon this will show the jobs in queue just right click on each job in queue and select cancel to clear the job in queue if there are still jobs in queue we have to performe the restart the print spooler steps by keeping the usb cable disconnected so that all the jobs are clear when the spooler is restarted. One the spooler is restarted just reconnect the usb cable and check if there are any jobs in queue. If there are no jobs in queue we can move ahead an set the print directly settings. Steps to set the print directly settings: Right click on the printer icon and select properties then click on the advance tab and under it select the option print directly to printer and click on apply and Ok to save the settings. Once done try to print to check with the issue. If the issue presists you can try to check with the port settings. Right click on the printer icon and select properties and then click on the ports tab and check if the virtual usb001 port is selected if not select it and click on apply and ok to save the settings if you don't see any usb port check if you have dot4 port in the port list select it and save the setting and try to print this should resolve the issue.. Once done try to print and if the issue presists you can try to refresh the usb ports. This will re-detect the usb drivers for printer and you will be able to print after restarting the computer.
Sep 16, 2007 | HP Photosmart C3180 All-In-One InkJet...
Blurry printing fro lexmark x4270
May be too much info blocking up print memory. Before printing off sites, make sure you clear print queue and slect printer friendly versions. Check to see if your printer has a work online or offline setting in preferences too.
Sep 05, 2007 | Lexmark X4270 All-In-One InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
371 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
