Question about Dell DVD-rom DVD Drive
Dvd/cd drive It is not working and when I check properties I receive the following error message: "This device cannot start - Code 10"
  • luis_cuesta5 Dec 26, 2008
    Same Code 10 msg.I have even changed drives but the only thing that does not load is the drive, the software driver loads find. I am running Windows Vista preminm SP1. I think that is where the problem lies. HP Notebook.
    President:
  • 1,257 Answers
GET YOUR PC PROBLEM FIXED
http://www.windowsguru.org
Posted on Jul 01, 2009
This device cannot start. (Code 10)
HI,
Information as from the Microsoft website:
Code 10
If the device has a FailReasonString value in its hardware key, that string is displayed as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
This device cannot start. (Code 10) Recommended resolutions
Here are some things that you can try to resolve this problem.
Update the driver
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
View the article in the Microsoft Knowledge Base
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base:
943104 (http://support.microsoft.com/kb/943104/ ) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers For further details: http://support.microsoft.com/kb/310123
Aug 25, 2010 | Microsoft Computers & Internet
Get a code 10 error message. it doesn't run any cd or dvd
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Jan 11, 2010 | Pioneer DVR-107D DVD±RW Burner
Cd rom not working. In the system devices it is listed with a yellow mark on it when I check the status it says "this device cannot start. (code 10)
Delete it from system devices, then reboot so it will be rediscovered. If that doesn't work, turn it off and physically detach and re-attach it. If that doesn't work, replace it.
Dec 04, 2009 | Dell Inspiron 1525 Notebook
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
You may see one of the following error messages:
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
Nov 08, 2009 | Dell OptiPlex GX260 PC Desktop
Code 37 on dvd drive
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
Windows cannot initialize the device driver for this hardware. (Code 37)
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
1. Open Control Panel and select System.
2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
3. Scroll down the Device Manager window and identify the faulty hardware from the list.
4. Right-click on the hardware and select Update Driver.
5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Aug 04, 2009 | Dell DVD-rom DVD Drive
Code 10 no cd/dvd drive found, unable to burn cd?
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Jun 24, 2009 | Apple iTunes
Pioneer DVDRW DVR-K17B ATA Device won't run any CD's;
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Dec 09, 2008 | Pioneer DVR-107D DVD±RW Burner
Matshitu uj-850s driver is not working on my laptop. Itis at a code 10
hi there,
do u mean drive ??? cause this CD-RW/DVD-RW COMBO Drive would not need a driver since windows would install it set of generic drivers for this drive.... but here is a little file that would help u out:-
Download this registry fix for missing/not working CD drives: http://aumha.org/downloads/cdgone.zip
How to Fix a Code 10 Error
A Code 10 error is due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
If the device due to which the error has occurred contains the value FailReasonString in its hardware key.
then this string is displayed as an error message. Otherwise, the device displays the following error message:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Most of the time, you can resolve this error by updating the device driver for the faulty device. To update the driver, select the System option from the Control Panel. In the System Properties dialog box, select the Hardware tab, and then select the Device Manager button. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Apr 12, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
CD rom drive not working
sounds like it's gone home early. replacement will do the trick..
Mar 06, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Computers & Internet Logo
259 people viewed this question
Alun Cox
