Question about Internet KB-9828 PS/2 -Multimedia Mini Keyboard (Silver-Black) (KB9828)
Need driver for KB9828 mini keyboard - Internet KB-9828 PS/2 -Multimedia Mini Keyboard (Silver-Black) (KB9828)
Why can't I get a new usb mouse and keyboard to work on a very old Win98SE system that has working usb ports, but the old mouse and keyboard were ps2 connection?
You need to go to the manufacturer of both the keyboard and the mouse web sites and download the windows 98 drivers for both of them and install them.
Jun 28, 2012 | Computers & Internet
I brought a akai mpk mini and when i plug it into my laptop, the sony vaio ns-series VGN-NS30E says i need driver software to use it. the keyboard works on my computer though (dell volstrom 220 mini...
Your machines are different and likely have different interface chipsets. Some newer machines have more built in plug-n-play than others. There is so much incompatibility that it is a wonder that any of the stuff works together. You need to install the needed driver... NOTE: there is a lot of incompatibility between OS versions... so if for instance you are using XP on one machine and Vista or Windows 7 on the other there are a LOT of incompatibilities. ALWAYS check the requirements for the computer with the specs of the device to be connected. MOST of the problems are due to OS variations. Check for driver updates on the Sony site
Jan 29, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Frozen keyboard - taking battery out and then putting back did not fix this
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Dec 30, 2010 | HP Mini 1000 Netbook
My compaq mini laptop key e and o not working on the keyboard.
Replace the keyboard -- nobody "fixes" laptop keyboards, due to the lower cost of replacing it.
Dec 22, 2010 | Computers & Internet
Touch pad and keyboard do not work after re boot on dell mini inspiron
Get a USB mouse, click start then right-click computer then select manage. Uninstall your mouse and keyboard driver then restart your system. Windows will automatically reinstall the drivers and you might need to restart your system again.
May 30, 2010 | Dell Inspiron Mini 10 Notebook
The keyboard of my new inspiron mini 10 has an inversed touch between @ and "
SCancode is interpreted incorrectly by the OS> EIther the keyboard is faulty - but if it just started recently - control panel / system / device manager / /uninstall hardware driver for keyboard and reboot with mouse
Oct 24, 2009 | Dell Inspiron Mini 10 Notebook
Zippy's USB Mini mouse Lookig for Drivers
THE DEVICE MIGHT BE CORUPT. TRY IT ON ANOTHER PC. IF IT DOES THE SAME PROBLEM TAKE IT TO YOUR SELLER FOR A WARANTEE.
THANK YOU
WONDER
Sep 16, 2009 | Zippy WK-713 USB MULTIMEDIA SUPER SLIM...
A4tech Mini Optical Mouse (mop-35) driver
try this web to download your Driver, just look the exact driver of your Mouse
Mar 11, 2008 | A4tech Mini Optical Mouse mop-35
GE wireless keyboard - how to uninstall
all you need to do is plug in a normal keyboard & mouse and will work fine without removing your old drivers. but if you really want to go into control panel and add/remove programs and look for keyboard related program in the list. All the best John
Dec 25, 2006 | GE Optical Mini Mouse ho98094
Internet KB-9828 PS/2 -Multimedia Mini Keyboard (Silver-Black) (KB9828) Logo
54 people viewed this question
Laxman Bisht
Laxman Bisht
 Grubhead
Grubhead
