Question about Toshiba Satellite A135-S4527 Notebook
No power when battery ran down it powered off. will not work with ac power cord.
  • 45 Answers
Try removing your battery and then plugging in the AC adapter. The damage could also be to the motherboard or PSU. So keep that in mind but you may be able to get it slightly operational by removing the battery.
Posted on Jun 15, 2008
My laptop is not charging. i plug the power in but still doenst charge. im not sure if its on the power cords or on the laptop please help asap i need my laptop for school :(
Does the laptop work on AC ? Is the battery or cord/charged a replacement? First, try another cord/charger of the EXACT same specs as original. Second, Is the battery good? How old? Over 4 years? Have it tested. Beware of inexpensive aftermarket batteries and cord/chargers. I assume the laptop works on AC? If you unplug the AC , with battery in, the laptop shuts down immediately?
Nov 26, 2012 | Lenovo IdeaPad Y450 Notebook
Laptop Power Up Problem
Try booting under AC power with the battery removed.
Jun 05, 2008 | Gateway 400SD4 Notebook
I have a Dell Inspiron 5160 Laptop that has been working decently for me for a while. I have always had issues with the laptop recognizing the ac adapter but usually been able to spend a few hours and...
Hi there!
First the problem that you were having with the ac adapter can be fix by just updating your computers BIOS.
Now for the computer not turning on try this, first remove battery make sure ac adapter is unplugged then press power button for 5 seconds after that put in battery and then press FN + POWER at the same time this triggers the diagnostic on your computer if it runs then just wait if it will give you an error message. If it fails then try to use just the ac adapter that means battery should be unplugged.
Hope this helps!.
Sep 06, 2011 | Dell Inspiron 5160 Notebook
Computer was on AC power. Left unattended it shut down. Would not wakeup. Shut down fully, it would not come back up. Get a 2 short beep code. Invites an F1 to go to setup. Won't go to setup. Screen then...
Can you tell if your AC power cord is working? (Is there a light on the computer that comes on when it's charging?) If the power pack went dead, your battery could've died and now you get no power to the PC which is why it won't boot up.
To test, take out the battery and plug the AC cord in and try to boot up. If nothing at all happens without the battery, then your power cord or power pack is dead, and you just need to replace it.
May 29, 2010 | IBM ThinkPad T21 Notebook
Wont power up, power cord good. once plugged into laptop power cord stops working
As long as you are abslolutely sure the power cord is functional, without a more indepth analysis, it seems/sounds like the AC connection to the board is broken.
To rule out this conclusion as the failure point, see if you can borrow/buy or better yet, recharge your battery {assuming it has no charge left at this point}
Stick the charged battery into your rig and if it works, yes. The AC connection is broken - nothing a little bit of soldering won't fix.
If it works, will need to ask more 'protocol questions to narrow down the situation'.
...when you reflect on the usage of the laptop, is there a bit of manhandling when connecting the power cord? Do you run it mainly plugged into AC? Dell is infamous for dodgy AC connections strongly lending credence to a broken AC connection to the mobo.
Dec 07, 2009 | Dell Inspiron B130 Notebook
Dell xps m1210 won't power up with new battery. Check notes.
If it is working fine with a fresh battery then it is not a motherboard problem. It is either a bad ac adapter jack on the motherboard or the actual ac adapter cord is not working. Try cables2go.com as they have replacement ac adapters for almost everything under the sun. Hope this helps.
Jul 10, 2009 | Computers & Internet
My dell gateway M305 doesn't hold a charge. If i take it off ac power for even a minute it will notify me of critical battery power, then power down shortly afterwards. Can anyone help?
Replace the Battery.
(Have it tested first to be sure that's the problem)
If you find that the battery is functioning properly, then the problem is your AC Power Adapter (power cord) so replace whichever one doesnt work.........in otherwords, take it to any place that sells dells, ask them to test your battery vs a new one, and your power cord as well!
Apr 20, 2009 | Gateway M305CRV Notebook
Toshiba 400cs does not boot
Removed battery and plug in AC cord. Unit booted up and ran fine.
Apr 22, 2008 | Toshiba Refurbished SYSTEM BOARD 400CS...
ACER ASPIRE 3002WLCI
Probably a voltage regulator, they are usually available on ebay, but I suggest having it done at a repair centre.
Jan 28, 2008 | Acer Aspire 3000 Notebook
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Toshiba Satellite A135-S4527 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
