Question about Norelco Health & Beauty
The blades came off the head of the shaver and we do not know how to put it back together.
  • Norelco Master
  • 1,610 Answers
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/philips_norelco_heads_replacement
Posted on Nov 08, 2010
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
MY DAD DROPPED HIS PHILIPS 7300 SERIES AND THE SHAVING HEADS FELL OUT NOW WHEN WE THINK WE'VE PUT IT BACK TOGETHER , THEY WONT SPIN ANY IDEAS PLEASE.
Sounds like one of the heads are damaged or something is not put together correctly causing it to jam. Watch the video below to make sure that you have the heads in correctly.
If you have everything in correctly and it stll jams, one of the heads is likely damaged. You can remove them individually and turn the blade clockwise inside the comb with your fingers. Each should turn freely. If any will not turn, you will need to replace them. You will find replacements for 7300 series shavers at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
May 04, 2011 | Philips Philishave Cool Skin HQ6760/HQ...
I have a Philips Norelco 7310XL razor and I have a problem. I recently moved, and in the process, something happened, and my razor isn't working. When I turn the razor on, the blades turn slightly and then...
It sounds like maybe one of the blades is damaged and it is jamming the whole thing. Try taking apart the head assembly and then insert each head one by one turning the shaver on in between each one. This should identify if one is damaged and causing the problem
If you require new heads, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Sep 18, 2010 | Philips Norelco 7310XL Electric Shaver
Can't put blades back
mcdevito75 here, Bring the shaver to any drugstore in your area they should be able to help out.
Jun 24, 2010 | Igia AT7352
The spring has fell out of the head when i was changing top i dont know how it goes back together
pull the black thing with the little blades until it detach, put the spring inside the hole, reassemble
May 09, 2010 | Braun Silk-epil 3370 Epilator
I dropped the razor and the 3 heads fell off, nothing is broken, but I can't figure out how to put it back together Help!
all you have to do is put them back in there place you should have two legs that spring out from the blades align them with the 2 holes on the shaver and push them in
Oct 21, 2009 | Philips Philishave HQ8150 Electric Shaver
How to disassemble Braun 4505 shaver. Cutter stopped working.
You want to go to this site and get a repair manual. http://web.archive.org/web/20041025223715/63.230.9.155/braun/Srv_Man/SHAVER/
Follow the instruction and remove the swivel head. Then remove the 2 screws at the bottom. I still have problem sliding the two side head support off.
Apr 08, 2009 | Braun 4501 Electric Shaver
Cannot put blade assembly back together
Sounds strange, since I don't think that the HQ5 heads in the shaver have the pointy parts that other shaver heads have. If your comb has 2 pointy edges, make sure they are located correctly in the head housing - they will need to be located inwards, with the the spindle that the retaining bracket attaches to in the center of the the two pointy parts.
But apart from placing the combs in first, locating the cutters in then putting the retaining bracket in (which may be broken if it won't fasten properly) I'm not sure what you can do, other than calling your local Philips Service Centre,
Apr 07, 2009 | Norelco Reflex Shaver 5885XL Electric...
How do I put my shaver back together after I replaced the blades?
For Remington clippers, the smaller blade has a groove which matches a beveled edge on the trimmer body. Line it up, align the larger blade to its screw holes, insert and fasten screws until tight, and you're good to go. Oh yeah, and try to center the small blade.
Mar 12, 2009 | Health & Beauty
Health & Beauty Logo
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
