Question about Philips 42PF9631D 42 in. Plasma Television
Dear Expert !! I have Phillips 42 Plasma TV. model No : 42PF9631D/37 since last week, it didnt turn on and just red light blinking 7 times. I check google and one of solution was change capacitors is it right?? and where can i buy those parts?? Best Buy, Target, or Cirkit City?? are they selling???
  • 10,515 Answers
Let me provide you complete details as i am aware of this 7 blinks error.
Either the power supply has an issue , or you have a bad buffer board and Ysus scan board or both. 4, 5 or 7 blinks may mean power supply , 6 blinks usually the buffers and y board.
A repairman will usually just order the boards and you will spend over $700 probably around $850
It could be just a few bad capacitors on the Power Supply.
The Y board if its bad it should be replaced with the buffers together
If you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
The ones you are looking for are located almost center bottom of the power board,Usually I can see them clearly with the back on simply shining a light into the back through the holes.
look at the photo I am uploading to see what a bulging cap looks like
Dear
Expert !!
With the back removed you will see a few circuit boards the large one the AC cord runs to is the power supply, it has alot of capacitors on it (cylindrical standing straight up soldered in and marked on the sides with the positive/negative sides and uf and Volts values)
Philips uses 2200uf or 3300uf at 35Volts rating capacitors, they cost about $1-$2 each . Read the side of your caps for the correct value
usually I replace two of them (or all the bulged on top ones) .
To buy capacitors click here
The power board and back unscrew with a torx bit and screwdriver size 10 and 15 , if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
You can replace the whole power supply, but Philips has a few versions in their sets and some so called replacements won't fit due to cable location (sockets) being in a different spot.
If there is a blinking red light on the TV count the blinks,if it still blinks after replacing the swollen cap this would indicate another issue.
I hope thats all it is (usually is), if there are no bad caps post again so I can tell you buffer troubleshooting steps and locations.
here is Philips Phone 1-888-744-5477 in case you need it for exact part numbers or check encompass.com login as a guest and run a search by model number.
Above is the picture of power supply board. Not to mention that kindly take all the precautions before attempting to repair this TV.
These caps could be easily available from radioshack or fry's.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 07, 2010
I have phillips 42pf9631d/37 that wont turn on and blinks red seven times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 25, 2011 | Philips 42PF9631D 42 in. Plasma Television
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
TV will not turn on, the light goes from green to red.
I own the same model. You have 1-2 Blown Capacitors. Take off the back cover, And look towards the center of the main power board. Look towards the center of this, and there are 2 capacitors side by side. You should see them swollen at the tops, even maybe a little black residue that has come out. I soldered on 2 new ones, and bingo! I would suggest replacing them both.
Dec 13, 2008 | Philips 42PF9631D 42 in. Plasma Television
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
Aug 07, 2008 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television Logo
219 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
