I HAVE A FUJITSU-SIEMENS TV COLOR LCD MYRICA VQ40-3SU MODEL, I' VE TO CHANGE THE POWER SUPPLIE MODULE INTO THE TV BECAUSE DURING A STORM, IT WAS BROKEN FOR AN IMPROVVISE HI TENTION VOLTAGE. COULD YOU TELL ME IF IS POSSIBLE TO HAVE A NEW REPLACEMENT AND HOW MUCH IT COSTS? MANY THANKS FOR YOUR ATTENTION, GREETINGS AND BEST REGARDS, MARIO ALFANO FROM ITALY.
5 Suggested Answers
  • 191 Answers
SOURCE: akai lct3201ad - cost to repair vs. replace power supply
lcd parts.com
Posted on Nov 10, 2008
  • 117 Answers
SOURCE: Black screen on my Fujitsu Siemens Computers Myrica television
sound no picture does it flash when first powered on ? its the invertor board it controls all the lamps
that light the screen/shine torch into screen you
will see picture/needs repaired google{ohm supplies uk}
Posted on Apr 18, 2010
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
Thompsons196
  • 350 Answers
SOURCE: hi, my Fujitsu Siemens
If you already checked the connections then your backlight just went out on it
Posted on Jan 27, 2011
TV Will not power on
HAVE YOU CHECKED PLUG AND INTERNAL FUSES
May 28, 2015 | Televison & Video
Osd locked fujitsu
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 19, 2014 | Fujitsu Siemens Siemens Basic Line B17-1...
Hello. I have a Fujitsu Siemens TV Myrica PDP-TVP PQ 42-1, and it is 5 years old. No problem until today. First did the colours slowly change. After re-starting the colours were ok for a short while,...
Sounds like to me you either have a video processing problem or you have a powersupply issue. The only way to tell is to open set up and check the powersupply voltages and then go from there.
Let me know if you are willing to open that baby up and then we can check for correct power supply
voltages... Talk to you later. HDTV GURU JAY
Mar 16, 2011 | Fujitsu Siemens Televison & Video
We got a Myrica PQ42-1 that takes the fuse in our house all the time. After 2-3 times it turns on. Is this normal??
I have the same problem. Returned the TV for warranty repair and got it back still with the same problem. "Change your fuses to 16A slow" was the message from FSC service shop. (16A=3500Watts!)
I have mounted a 10A fuse directly 'between the TV and the 230V outlet so the (house) fuse does not drop.
Now my ******* TV went all black, probably the backlight.
Jul 08, 2010 | Fujitsu Siemens MYRICA P50-2 50 in. Plasma...
Apr 18, 2010 | Televison & Video
Sometimes works perfectly other times wont even come on model lcd w9za
ronniecam, Likely it's just one bad thermally intermittant solder connection on units internal "switch-mode-power-supply/ inverter supply printed circuit board or bad swollen/leaky electrolytic filter capacitors. Do some reading in my and other LCD technician's fixya profiles for more info on this very common problem. 12fixlouie
Mar 16, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Do I need a battery to run the PC Tablet?
THe manual for your specific model can be found here: http://support.fujitsu-siemens.com/Manuals/ShowDescription_KMT.asp?DokuID=202607 Documents for othe models and languages can be found here: http://support.fujitsu-siemens.com/com/support/manuals.html
Sep 24, 2006 | Fujitsu Siemens Stylistic ST5022D Tablet...
Televison & Video Logo
316 people viewed this question
Top Televison & Video Experts
Electro Med Services...
