Question about RCA Televison & Video
I have purchased the converter box to receive digital signals and my tv doesn't have the red/yellow/white connections. Is there a model of converter that will work on this tv which is an RCAModel F25423 Gold Plus(2001) Chassis #CTC203AC5 When I hook it up to the antenna thru the converter it gets one channel, but won't move off that channel. Could it be possible that this tv is already digital? Any help will be greatly appreciated..Thank you LaLauretta Sparks
  • heymaw Jun 16, 2008
    This analog to digital converter box I bought is mfg. by Magnavox and the instruction book calls for the red white connectors. Do you know if any of the converters on the market will work with just the RF connectors? I have no tech knowledge but I can usually follow set up instructions. There are two inputs on the back of this tv but they are not color coded and I believe are game ports. This is not a projection tv. I have thrown in the towel. Just need to know if there is a converter that will work with just the rf connector. Appreciate the fast help tho...
  • 21 Answers
THE CONVERTER BOX HAS R.F. OUTPUT. JUST HOOK IT UP AND PUT THE T.V. ON CHANNEL 3.(OR WHAT EVER THE INSTRUCTIONS THAT CAM WITH THE BOX) YOU WILL NEED TO CHANGE THE CHANNELS WITH THE REMOTE THAT CAME WITH THE BOX. YOU MIGHT NEED TO SET UP THE BOX (SCAN FOR CHANNELS) THAT IS ALL IN THE INSTRUCTIONS THAT CAME WITH THE BOX.
DON.
Posted on Jun 15, 2008
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
I have a standerd tv and i want my kids to use it and watch netfliex, how do i connect it
  1. A digital television adapter (DTA), or digital-to-analog converter [set-top box], or commonly known as a converter box, it is a television tuner that receives a digital television (DTV) transmission, and converts the digital signal into an analog signal that can be received and displayed on an analog television set.
Aug 01, 2014 | Televison & Video
Going from cable to coby converter box
cONNECT A REGULAR OR DIGITAL ANTENNA TO THE rf INPUT ON THE coby..
Do one or both of following.:
Connect rf output from copy to rf input of TV. (set both units to channel 3, or 4 --must match)
or connect three RCA connectors (either three cables or single cable with Yellow-Red and White connectors) to the matching
connectors on TV and COBY.
This might involve DISCONNECTING some connection from cable box.... but you may decide to keep both connected ( one item to each option as described above. ) The signals from the RED WHITE and YELLOW systems will be available on the TV when you set the TV for LINE input ( there might be more than one choice of LINE-IN selections on some TVs.
May 11, 2014 | Coby DTV102 ATSC STANDARDDEFINITION TV...
I purchased a 32" Dynex
You only need to plug in the Red/White/Yellow plugs. Make sure you plug them into the correct colors on the TV. Most HDTVs have Red/Green/Blue ports. DO NOT use these ones, they are for receiving HD video signals. A lot of HDTVs also have the Red/White/Yellow plugs on the side of the TV (often labeled "Game", maybe something like "Video 3")
The Red/White/Yellow cables are known as RCA cables or Composite cables so look for any ports with those labels as well.
May 09, 2011 | Nintendo Super NES Console
RE:Samsung Model #TCD1341, Manufact./Aug.1995, digital-capable?
No it does not have a HD tuner. The simle way is a Digital Converter box for about $40.00 it will have composit out (red, white and yellow leads) plug these into TV you will have a converted Digital signal that will make your old set
look like a HD set.
Nov 08, 2009 | Samsung TCD1341 TV
Model 6620l-cta I had cable and now I don't is it possible to watch this TV without cable. Is there anyway to switch it to a TV mode?
TV is no longer analog, it is digital, which means NO over the air broadcasting for your TV to receive. The ONLY way to receive a picture on this set is to have some sort of input being broadcast, via Direct TV, Cable, etc. You could always use it as a stand alone DVD monitor if you choose. I hope this helps.
Oct 26, 2009 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
Receiving no signal with converter box
Where is the "no signal" coming from, the converter box or tv? If tv then unplug the dvd player and plug the plugs into the converter so the wires go from the converter into the rf modulator. set the tv up to watch dvds and try your channel scan gain. If it works then post again and we'll figure out the best way to connect the converter and dvd to the tv.
Jul 30, 2009 | Apex Digital (AL-A300ATX) 300-Watt Power...
Digital hook up
No, you will need an ATSC tuner box that will receive digital signals from the antenna and convert them to channel 3 or 4, and put the video and audio out on RCA plugs - yellow, red, and white.
tom
Apr 12, 2008 | Proscan PS27108 TV
Sanyo TV - DS25390
In your model you have to purchase one video RF converter. RF converter contains one video input in yellow colour and two audio input in red and white colour and one cable connector as output. Connect the dvd output to this converter and tune the tv program in which place you receive dvd signal.
Aug 26, 2007 | Sanyo DS25390 TV
Televison & Video Logo
116 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
