Question about Avanti DW18 Built-in Dishwasher
HI There, thanks for being willing to take my question. We have a 1 year-old White Avanti Dishwasher Model Model DW18/DW19PSS/DW181SS PROBLEM: detergent dispenser often does not fully open, leaving soap in the dispenser even thru the rinse cycle... it seems to get hung up on the upper rack. i can even hear the dispenser door pop open when i open the dishwasher after the cycle is complete, making me wonder if there is enough clearance for the dispenser door to flip completely open. THINGS I'VE TRIED: 1.pushing the rack and rails all the way back so as not to interfere with the flipping up action of the dispenser door 2. rinsing, brushing out the spring latch on the dispenser, in case it was clogged with soap 3. using less soap 4. not putting anything on the top rack that would get in the dispenser door's way when it's time to open. 5.. going to avanti website for help on the subject and studying the manual. I'd appreciate any other suggestions you might have short of calling the repair people now that it's probably just a month out of warranty! thank you thank you! Rebecca
3 Suggested Answers
BarrettDenCo
  • 1772 Answers
SOURCE: I have an Avanti DW18
Sorry to read about your problem.
Their is a 60% chance that your cold water inlet valve is stuck. 30% that you water leval sensor is defective.
I suggest you contact a local service company to repair your problem, this should be 1 hour or less service call.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck.
If you are in the Denver area, I can help you out
Posted on Dec 21, 2010
  • 653 Answers
SOURCE: Looking at buying an 18
The timer is going bad, and a replacement will cost more than the dishwasher. Go look at a new one. They only run a few hundred bucks and will last for at least 10 years without any problems. I bought a basic model for a house I was selling a few years ago for $185.
Posted on Sep 11, 2011
Avanti not filling
Check that you are getting water to the water inlet valve. Sometimes they fail and will not let water into washer. I have replaced a number of them and they cost about 30-50 dollars. You can goole appliance parts and find a company that you can order it from. hope this helps
May 04, 2014 | Avanti DW181SS Stainless Steel Built-in...
Avanti dishwasher won't drain
hi could be two things... 1 could be you have food or broken glass in pump..it wont spin if anything there... u need to unplug from mains ...undo filter and remove ..you may have a larg metal filter remove too... you now have access to pump sump area... empty all water left in there with cup... it might SMELL :) when pretty much empty run VERY GENTLY around bottom of pump well... could be broken glass so do it slowley ... remve aything in there .. you will find a hole at bottom put finger in and turn propeller pump see if its stuck.. it it turns .and nothing is in way.. put back together and test dishwasher on quick wash.. if still not emptying change pump..
mark 07779933829 ===== TURN OFF AND UNPLUG FIRST=====
Nov 23, 2011 | Avanti DW18 Built-in Dishwasher
I have a new Avanti dishwasher...but am having problems with it. At the end of any cycle the dishes aren't clean. They are still covered with 'bits'. I've lifted the funnel bit out of the base but no...
check the holes on spray arms are not blocked with food ect... if ok u need the wash pump stripped or the iwms cleaned ... bsc appliances 07779933829 uk
Feb 27, 2011 | Avanti DW18 Built-in Dishwasher
I have an Avanti DW18 dishwasher that will not fill with water. No stopped up hoses. Dains water and if i add water manually it pumps it out.
Dec 21, 2010 | Avanti DW18 Built-in Dishwasher
Where can I find a cabinet as in the picture above?
what you have in the pic is a custom setup, try your local cabinet company. Or if you know a good carpenter they could make one for very little expence
Jul 08, 2009 | Avanti 18 in. DW19PSS Platinium Built-in...
The dishwasher continues to drain and the timer does not move
Sounds like the timer needs to be replaced, especially if the tub is empty of water, and the timer will not advance no matter how long you leave it there.
Jan 24, 2009 | Avanti DW181SS Stainless Steel Built-in...
Avanti DW18 Built-in Dishwasher Logo
99 people viewed this question
Top Avanti Dishwashers Experts
Robert Plante
richie46
David Ellis Rhea
Are you an Avanti Dishwasher Expert? Answer questions, earn points and help others
