Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer - smartheat - quietpak9
I need to replace the front control panel but I can't figure out how to get the current one off. Any suggestions? Also once I get it off is there anything special to know or I simply unhook the old and attach the new? Thanks.
  • jgb555 Jun 16, 2008
    when you say remove top 3 screws along rear I assume you mean rear of the machine? I ask because its in a closet and i cant see the back of the machine and i see no screws visible anywhere along the outside of the control panel.
    New Friend:
A reading "E1" appears after a few minutes of operating then dryer then shuts off.
Posted on Feb 20, 2013
  • 1,028 Answers
Remove top 3 screws along rear..remove screw each side of control on top .next while pushing toward rear on top edge of control pull up and out at bottom edge where control meets lower section lift up each corner may need to remove screws holding main control in place panel has 1 02 connectors on main board there is a release clip on each connector
Posted on Jun 15, 2008
My Kenmore Elite Smartheat QuietPak9 dryer quite blowing hot air.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Jan 06, 2011 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite Smartheat quietpak9 model HE4, keep turn off after 15 to 20 minutes, it does getting hot. Could you please let me know what will be a problem. I bought it used so I am not sure how old is...
might need a clean out keeping heat inside of dryer,or you have abad motor,take the vent line off the back of dryer and run it to see if the block is in the vent line or in the dryer,also take off bottom panel,unplug dryer,take out lint filter and then remove the duct that the filter slides into,if it's blocked clean it out and you should be all set,usually the thermal fuse pops when this happens so that's why i say you could have a bad motor
Dec 15, 2009 | Kenmore Elite HE4 Electric Dryer
Gas dryer wont heat
You may have a blockage somewhere in your exhaust line. I had to have my professionally cleaned, but it fixed the problem.
Dec 11, 2008 | Dryers
New Machine Control Electronics needed?
HUH????? just change interface(buttons and board ) have never took time to ck resistance.. front interface just tells machine control what to do
Sep 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 - Smartheat Quietpak9
Dryer heats but will not dry clothes. Uncloged linted in screen and where the tube is. Did not fix the promblem. Could it be the heating element? And if so what is the cost to replace it?
Nov 15, 2007 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
Manual might be available on line type in your make and full model. Could well be the bulb that blew. Sounds like the door switch thou i see by other postings some times the filters can cause a similer problem
GUEST. 1. start switch is faulty...oops is it eletronic?it so disregard that. 2 drum is to tight 3 motor or switch on motor faulty
smitty123. Will drum turn by hand??? Can you hear the motor hum when you close the door???
Oct 27, 2007 | Kenmore Elite HE4 Electric Dryer
Not starting 1 yr old kenmore elite smartheat quietpak9 HE4
Control panel moisture 9/10 times.... or check the fuse under the lower front panel ($12 sears)
Nov 28, 2006 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
152 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
