Question about Samsung RS265LABP Side by Side Refrigerator
Samsung Model RS255BASB- block of ice is forming behind the second drawer on the freedge side which won't let close the door, I had to remove the drawer to closed the refrig door. Any suggestions.
  • 56 Answers
SOURCE: Large ice block is forming behind the fruit drawer.
i assume you have a model 650 or 550. Your drain line has clogged then frozen. You need to defrost the ice then clear the drain line. I usually knock a majority of ice away then defrost the rest. Once you have defrosted the line you need to clear it. I use high pressure nitrogen to blow them out, but a turkey baster will do just fine. Fill the turkey baster with water, disconnect the drain line from the drain trough. While holding the baster into the drain line squeeze the bulb to force the water into the line. It may take a couple of tries. Reconnect the drain to the drain trough and you should be all set. If you let this go too long the insulation may be saturated and you will have to have a tech install a drain tube heater kit. If you have questions call the factory at 800-222-7820 or go online to the locator page: http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
  • 56 Answers
SOURCE: Ice behind the high humidity compartment
You have clogged train which has frozen over. There is a factory kit to add a heater. You firrst might want to try and defrost the tube using warm water after your remove the ice. You want to make sure that water will flow down that trough and passed the tube. THe watere goes to a drain pan below.
Posted on Dec 02, 2008
tborn6
  • 700 Answers
SOURCE: SM-RS255BASB
there are 11 screws that hold the regrigerator cover on. the light cover is the easist because it snaps in besides the 1 screw in the middle, the htere are 4 mre that have to caosnm e out behind the ligeht cover. then thered are two in the middle that are covered with aa blank offf cover. the htere's the 2 for the resevour and finally the two on the bottom
Posted on Dec 24, 2008
  • 78 Answers
SOURCE: Kenmore refrig model 10671182101 water leaking in the interior
iced up drain , clean and defrost drain
Posted on May 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Samsung RS2545 side by side refrig, the drawers in
Because your refrigerator has dual evaporators you can start by defrosting. Yes the old time defrost. Once the ice is gone on the refrigerator side lets try slowly adjusting the fresh food sections to temps acceptable to the foods safe temperatures. I will send you the service manual but if a sensor has malfunctioned you may need to call or order parts. Sea Breeze
Posted on Jun 27, 2009
The freezer has a white plastic back panel with vents to blow the cold air into drawers. That thing pulled away (ice formed behind it) - how to put it back?
there is some ice that has frozen the door in a fixed potion, if you have hair dry put on warm point toward where it hinges other than that call some service person to help you.
you mite call the manufacture customer service dept. ask for service
technician, explain whats wrong and see what they say. it never a bad question, or to ask for help!!
www.ask.com/mfg.name/make/model/customer/service/telephone#/
Oct 06, 2015 | Refrigerators
Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
Is there a drain at the rear for when it defrosts that has become blocked? Defrost fully and clear drain hole
May 20, 2012 | GE Profile Arctica Stainless Steel Top...
See previous answer re drain blockages. Also check condenser clean and all fans working ok.
May 20, 2012 | Samsung Refrigerators
Top drawer of freezer seems to work but large bottom drawer not freezing even at -5degrees. Can this be fixed?
This problem seems to be two sided. A refrigerator defrost it is supposed to take the water from defrost down a pipe located behind the freezer rear wall to a pan below the refrigerator where there is a fan blowing warm air over the water to evaporate back into your home or business. If that drain is blocked your refrigerator will accumulate a large block of ice and frost behind the rear panel of freezer and temperatures will warm considerably in fresh food compartment and freezer. Here is one site I want you to read over=> Leaking Refrigerators Just What may Be Happening and here=> Leaking Refrigerators here is a link to a service manual=> LFX25960xx Service Manual Let me know if this service manual is close enough to your model number. At this point I am looking for air blockage behind the rear panel of freezer. If air is being blocked by ice and frost you can use a hair drier to help speed you up while melting ice. If drain is blocked use whatever you can to open the drain line mentions on the links I sent you to and let me know what is found, Thanks Sea Breeze
Feb 18, 2012 | LG LFX25971ST Bottom Freezer French Door...
What happened to my Samsung RS255BASB is a loud noise coming from the back of the fridge, one third the way up. sounds like a bad fan/ grinding fan. from the inside it's behind the area where there are...
The sound is of the fan touching the liner. They only way out is to change the bearing. And temporarily you can tap the area where the noise is coming from. When the fan straightens out the noise will stop. But this is not the remedy.
May 14, 2011 | Samsung RS265LABP Side by Side...
Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
Aug 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
SM-RS255BASB
Dec 24, 2008 | Samsung RS265LABP Side by Side...
Hotpoint FFA70 - Freezer door will not close properly.
The rear panel can be removed,i have done it.I removed the 4 hex head screws from the top & bottom of the panel,and firmly pulled it forward.The reason i say pulled firmly is that when panel came out the back of the freezer was solid with ice.I have defrosted the freezer,dried any water from the unit and replaced the panel.Fingers crossed,so far,so good.In my case this build up of ice was definately the reason the drawers were not sitting in the correct position,as it caused the rear panel to 'bulge' out.Hope this helps.....
Dec 11, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
My FFa70 hotpoint freezer will not close unless i take out all the drawers. What is the problem?
there is something wrong with the drawers position. they could have been installed in the reverse position or they could have been in the wrong placement. one could be on top while the other could be at the middle.
try putting the drawers one by one and check each time if the door could be close by then.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Refrigerators
Samsung RS265LABP Side by Side Refrigerator Logo
114 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
