Question about Coleman Heating & Cooling
I have a coleman model 3400-815 electric furnace and it is blowing hot air to one end of the trailer but not the other there are no holes in the duct work had it checked and no cold air in vents when furnace is off is there more than one heating element? or what could be the problem/solution?
  • 18 Answers
SOURCE: Heater blowing out cold air
Yes you could have a bad overload on the heater element which is fairly simple to fix. To test for this pull the heater out and get an ohmeter set it to continuity and check the continuity first through the entire heater element then if there is none pin point the overloads and check to see which one has no continuity.
Posted on Dec 23, 2007
22yooper
  • 828 Answers
SOURCE: Coleman Evron CH/CA unit won't blow the air through the vents
Relay for fan operation in the cooling mode may be bad and not bringing on the blower for the air.
Posted on May 22, 2008
Accurate Joe
  • 61 Answers
SOURCE: Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Posted on Nov 29, 2008
  • 69 Answers
SOURCE: Ruud achiever 90 plus gas furnace not blowing any heat
These new furnaces are trouble. Ive been in the htg trade for 25 yrs. The fan is running because they are now controlled by a timer instead of a temperature control. Rather than sensing a preset temperature and turning on the fan, it comes on by a preset time. Couple of things, does either of the doors have an inspection window? most newer furnaces have what is called a smart board. The board will flash a trouble code. ie: 1 long 2 short etc. #1 turn your thermostat to off, youll need 2 people for this! Go to the furnace, If it has the above mentioned inspection window ( usually about 2" round) while peering through the window have someone turn the thermostat to about 80 degrees. Let the furnace cycle and see if it flashes a code. If it does the codes are usually on the bottom door, May be on the inside. The most common cause is either a bad transformer, bad hot surface ignitor or pressure switch failure. Further questions feel free to ask. Steve
Posted on Dec 21, 2008
  • 8 Answers
SOURCE: chemical type smell blows into house
Change your filter.
Posted on Mar 10, 2009
Electric furnace coleman model # 3120A751. It won't shut off on its own. Just keeps blowing hot air any ideas?
something is wrong in the 24v. make sure no wires touching each other both behind the tstat and on the circuit board in the furnace.
and obviously r to red w to white y to yellow.....
Jan 27, 2015 | Coleman Heating & Cooling
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
I have 2 air conditioners on my Hampton trailer. I can't get my furnance to kick on. I have a R V Comfort .ZC duel control thermostat with zone 1 ,liveing room, and -Zone 2 ,bedroom, zone 2 will say gas...
I need to know what the furnace is doing .
Since you said furnace that's means force hot air and you have 2 Zone damper that's runs on 1 furnace ,correct?
If it's 1 furnace with 2 Zone is Zone 1 working
May 31, 2017 | Coleman Rv Air Conditioner Control Box...
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
I have a coleman evcon gas furnace in a 95 trailer the draft fan stays on until you tap on furnace
Most Coleman units in a trailer dont have a draft fan. Are you talking about the fan that blows air through the floor registers? If yes, then you will probably need a new fan/limit control. If you do have a draft motor, you would probably need a new circuit board or draft fan relay.
Jan 02, 2010 | Coleman Propane Forced Air Heater...
The Pilot on my electric furnace will not stay lit, blowing cold air instead of warm. The model is L8T-UH.
Is this a code for us to come over cause electric furnaces dont use a pilot light ha! Ha! (they uses electric heat strips for heat .....but if you want to give away money..........)
Dec 09, 2009 | Coleman Mach 15 Air Conditioner
Need help with problem
Once you lit the furnace did you turn the valve to the on position. Russ
Jul 20, 2009 | Coleman Propane Forced Air Heater...
I have an old 1985-86 coleman central heat and air need manual
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Mar 10, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
162 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
