Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Format not selectable in AV-4
When I select AV -4, with either the remote or the front panel buttons, format options are not available (only Timer and Autolock appear). I therefore cannot select 16:9 (widescreen) and cannot see the Apple TV screen except as wavy lines.
  • 8,596 Answers
The AV-4 port on this TV is more problematic than anything I've seen. Set the resolution of the computer to 1024 x 768, 60 Hz refresh rate. If still nothing, set to 800 x 600, 60 hz refresh rate. Make sure the driver for the cable you have running from computer to TV is up to date. There's not much you can do on the TV end - all the changes have to be made from the PC.
Posted on Jun 17, 2008
I want to use the RCA connections but I don't have the remote
To connect and select the input to TV to AV, you must have its remote control, as there is no Menu button at the front panel of this TV, to get into its menu option, and to select AV function.
Jul 04, 2012 | Symphonic ST427FF TV
Can't find input setting on old proscan tv. tried channels 90/91/92. only white fuzz
You are trying to connect the TV by AV setup. You have to select the input selection to TV to AV. If the TV have a Menu button on its front panel, you can enter into its menu options, surf through, and select the input selection window. Here you can select input to AV.
If there is no 'Menu' button on the front panel of the TV, you can'd do this selction. You must have its remote control to select this option.
Jun 01, 2012 | Proscan PS27125 27" TV
My tv is stuck on the video imput for my Wii and none of the front panel buttons work
Try to see if any of these four methods will work.
Sanyo TVs
1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote
2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV
3. Press TV/AV or INPUT SELECT on remote
4. Press SETUP, choose TV/AV, switch to AV
Sep 25, 2011 | Panasonic TH-42PX60U Television
How do you format a cd
For windows 7:
1.Insert a disc into your computer's CD or DVD drive.
2.In the dialog box that appears, click Burn files to disc.
3.In the Burn a disc dialog box, type a name for your new disc.
4.Click Show formatting options, and then click one of the following formatting options:
-Live File System
-Mastered
5.Click Next to prepare the disc.
and for CD-RW:
1 Insert a disc into your recorder drive.
2 In My Computer, right-click your recorder drive.
The 'Use with DLA' option in the popup menu should have a check mark beside it. If this option is not selected, click on the HELP button and follow the steps in "Using DLA With Your Recorder Drive" before proceeding.
3 Click Format.
DLA's Format dialog box appears. The options available to you will depend on the type of recorder drive you have.
4 Set the options in the Format dialog box.
a ) Type a name for your disc in the Volume label text box.
b ) Select either Quick or Full Format by clicking beside the option you prefer. DLA can perform either a Quick or Full format of your discs.
c ) If you have an EasyWrite CD-RW drive, you will have the option to create an EasyWrite disc by placing a check mark beside Enable EasyWrite. (See Using DLA with EasyWrite Drives for more information.)
5 Click Start.
If you selected Quick Format or you selected Full Format and your drive supports background formatting, you will be able to use your disc within minutes. If not, you must wait until formatting is complete before you can write files to your disc.
I hope this will help you
Jul 30, 2011 | Computers & Internet
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    Picture is to big for the screen
    This is a picture format setting. Some remotes has a button labled format. Press the button to change format options. Or select menu and go to picture settings and find picture format, and scroll through options to find a setting to your liking. Depending on you service provider (dishnetwork, directv, or cable) you may need to change the picture format setting on that device as well. Contact your service provider if your not sure how to access these settings on the service providers box (device).
    Apr 28, 2011 | Vizio L37 Television
    How do I change the default file format from Jpeg to PDF on a xerox M24??
    The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
    2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
    3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
    4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
    5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
    - Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
    Mar 28, 2011 | Xerox Workcentre M24 Color Copier
    How do I reset my yamaha receiver htr5730
    http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
    Page 52
    1 Hold down STEREO on the Front Panel
    "Factory Preset" appears on the front panel
    2 Press STEREO to select the desired setting.
    'Reset' To reset to factory presets
    'Cancel' to cancel without making changes
    3 Press STANDBY/ON to confirm your selection
    Jan 15, 2011 | Yamaha HTR-5730 Receiver
    I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
    Adjust the system's video output settings. Select the best output settings for the TV in use.
    1. Check the resolution supported by your TV.
    Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
    2. Select (Display Settings) under (Settings) in the home menu.
    3. Select [Video Output Settings].
    4. Select the connector type on your TV.
    Resolution (video mode) varies depending on the type of connector used.
    Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
    HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
    Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
    Composite / S Video *3 480i 576i
    AV MULTI / SCART *4 480p / 480i 576p / 576i
    *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
    *2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
    D5: 1080p / 720p / 1080i / 480p / 480i
    D4: 1080i / 720p / 480p / 480i
    D3: 1080i / 480p / 480i
    D2: 480p / 480i
    D1: 480i
    *3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
    *4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
    5. Change video output settings.
    Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
    6. Set the resolution.
    Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
    * The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
    If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
    If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
    7. Set the TV type.
    Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
    8. Check your settings.
    Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
    9. Save your settings.
    The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
    Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
    Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
    64 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
