Question about Refrigerators
I have had a KitchenAid KSS42d (could be 42M, since there is no label) for approximately 15 years. It has been reliable and generally low maintenance. In July, cooling capacity seemed to reduce. it was still cold, kept ice cubes frozen, but still noticably not as cold. Called a serviceman and they topped off the refrigerant charge, it was approx. 1/2 lb. low. He could find no other problems, leaks, etc. It worked very well for about the next 3 weeks and the same thing happened. I called the service man out again and he found the same problem, approx. 1/2 lb short of refrigerant, so he topped it off again. No charge/warranty service since less than 30 days. Now I am noticing water leaking, with increasing frequency from the bottom, left side, where the water dispenser supply tube comes out from the bottom of refrig, turns 90 degrees and enters the freezer door. Also, the water from the freezer door dispenser is coming out increasingly warmer. I keep the condenser clean and the compressor seems to be fine. There must be a slow leak somewhere in the refrig. circuit, but wouldn't know how to find it. I am completely unsatisfied with service/repair men. They cannot answer my questions, and I do not believe they are true experts on this equipment. The refrig/freezer has custom wood paneling and I am not interested in replacing the refrig/trying to match paneling doors. I would rebuild or repair as required if I was satisfied with the diagnosis and felt I had expert technicians working on it. Any advice??? Sincerely, David J. Ellner
  • 2 more comments
  • David Ellner Nov 07, 2010
    Thanks for the product info to help reduce the refrigerant leak.
    What about the water leak from the bottom?
    This is what I recently found, after sending my original post:
    I took off the base grille, along the bottom of refrig. The defrost pan was filled with warm, almost hot water. It seems to be immersed in defrost coils, which were also hot. After removing the pan, the defrost coils also seem to be coated with oil...
    Any ideas what's causing all the water, oil and resulting problem?? How often does the defrost cyce turn on? Maybe its got some kind of a defrost controller problem.
    Also, any advice about how to find a REAL EXPERT for KitchenAid in my area? I can call all the refrigerator repairmen I want and I seem to get the same response.
    I don't mind paying a premium if it solves my problem....
    Thanks.
    David J. Ellner
    Heatman101 was helpful with product info and generally confirmed what I had suspected.
    Could have used a little more detail about how the defrost cycle works and if/how this might be contributing to or even possibly causing the problem.
    I am satisfied with the general advice, thrilled about how quickly heatman101 got back to me and his continued dialog. I will definitely use this service again.
  • David Ellner Nov 08, 2010
    No apology necessary. Your information has been most useful and I am happy with your answer. The references in your last post were also very informative.
    My interest in the defrost cycle is more about: was it working correctly? and if not, could it be contributing to the capacity drop. Is it possible, the defrost cycle could be diverting some hot refrigerant gas into the refrig/freezer? Effectively reducing its capacity? Why, the 1 time I cleaned the defrost pan was it hot?? I do not know how frequently the defrost cycles, if coils are always hot (continuously used for condensing) or if changes in normal defrost cycle timing might result from the refrigerant leak.
    Sorry for all the questions and it is not important that they be answered. As I said, I am satisfied with your previous answers and information. it has given me guidence for finding a permanent solution.
    David J. Ellner
  • Refrigerators Master
  • 43,501 Answers
Hi David,
Yes it looks like you do have a leak in that system....and finding leaks in a refrigerator is a nightmare to say the least....
So this is what I would do....
1. find a new company that has techs that actually know their craft....and have them try to find the leak....fix it and recharge your unit...
2. buy this product.... then have the first company (or another one) place it in your system....they should be able to handle that.....it will seal your system and stop the leak......saving you a ton of money and headaches....
You are right... they should know that once you have a leak...just recharging is just a temporary fix....
heatman101
Posted on Nov 07, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 07, 2010
    You have the oil there because the leak is in that area... the freon will dissipate and leave the oil behind...
    The water is condensation from the lines not be charged correctly...
    To find a good tech I would try to call Kitchen Aid directly and see if they have a recommended dealer in the area and if they will give them direction and stand behind them...
    heatman101
  • D. Floyd Kolb
    Sorry David,
    Did not swell on the defrost issue because I did not see it as relevant to your problem...
    Glad to be of a help though...
    Good luck with getting things fixed and going again!!!
    Here are a few tips that may help you with more of the defrost details...
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    heatman101
I am trying to work out how old my cat is in human years,she's 19?
A cat reaches the approximate human age of 15 during its first year, then 24 at age 2. Each year thereafter, it ages approximately 4 "cat years" for every calendar year. So a 5-year-old feline would be approximately 36 in cat years. Your kitty is very old, if measured by these figures. I found this info on the Internet. Google "how can I tell how old my cat is in human years" and you'll get a lot of information. Good luck.
Mar 10, 2017 | Cats
WHAT YEAR IS THE kiTCHENAID DISHWASHER MODEL KUDDO1DPPA
approximately 2004. Could tell exactly with the serial number.
Oct 12, 2014 | KitchenAid Dishwashers
Where can I buy cheap yet reliable label makers?
Try this website, it has a rank of the best label makers in less than $50: http://voices.yahoo.com/the-best-label-makers-buy-less-than-50-1848802.html?cat=15
Jan 24, 2013 | Office Equipment & Supplies
My nokia 5210 does not stop switching on and of
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Oct 06, 2012 | Cell Phones
Ksm90 mixer won't unlock
Look for a reputable dealer that repairs KitchenAid mixers. It is worth the little extra money to keep it going well. I had a much needed repair 15 years ago...... it was 8 years old then, and it is still in great shape and working superbly!!
Aug 15, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Have a 15 years old KitchenAid Surcare two speed 1/2 hp motor washing machine. part # 3361989 Machine is still working Would however I would like to know what kind of maintenance it needs and how to g
This machine needs no routine maintenance. If it's lasted 15 years, then you have treated it well, not overloading it with too many clothes and putting a strain on it. The tub rusting out may be your biggest worry. The schematic for the electric wiring, the diagram for the machine layout and the tub will be in the owner's manual.
May 14, 2009 | Washing Machines
Ntl starview codes
StarTech.com StarView SV431USB - KVM switch - USB
  • Mfg # SV431USB | Softchoice # C45933 | UNSPSC # 43211604
browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy9jbmv0l21pzhmvstywnjk0os5qcgc%3d&b=0 eval(parseJS('\rvar wcFrame = document.createElement("iframe");\rwcFrame.src = _39_/catalog/webcollage-iframe.aspx?sku=C45933&lang=en-US_39_;\rwcFrame.id = "wc"; wcFrame.name = "wc"; wcFrame.frameBorder = "0"; wcFrame.height = "30"; wcFrame.width = "155"; wcFrame.scrolling = "no";\rvar wcDiv = document.getElementById("ctl00_MainContent_wcd_wcdiv");\rif (wcDiv) { wcDiv.appendChild(wcFrame); } \r')); Product Highlights
  • KVM switch
  • USB
  • 4 ports
  • 1 local user
  • USB
  • 1U
Real-Time Availability Quantity: Usually ships in 2 business day(s). browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy9iz3mvmtj4mtitcw1hcmsuz2lm&b=0 eval(parseJS('\r\rfunction hidePNA() { $("#quantity").hide(); }\r\rfunction showETA() { $("#product-eta").show(); }\r\r$(\rfunction(){\rif ("True" == "True")\rapi.callAtlas("progress_ctl00_MainContent_stock",Softchoice.Web.WebServices.PNA.GetStockCount,"200","C45933",populateStock_ctl00_MainContent_stock);\rif ("False" == "True")\rshowETA();\r}\r\r);\r\rfunction populateStock_ctl00_MainContent_stock(stockCount){\rvar stock = $get("stock_ctl00_MainContent_stock");\rif(stockCount <= 0 ){ \rhidePNA(); \rshowETA(); \r}\relse {\rstock.innerHTML = stockCount + " In Stock";\r} \r\r}\r\r'));
  • $87.39
Qty:
  • browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy9idxr0b25zl3byb2r1y3qtchjpbnquz2lm&b=0
browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy91as9hy2nlc3nvcmllcy1sb2fkzxiuz2lm&b=0 StarTech.com's SV431USB is the reliable solution for server room and industrial computer environments. The SV431USB is a reliable computer management tool that allows you to control multiple computers from one console; minimizing downtime by making connected computers and input devices available as soon as they are attached. An all-metal, chassis provides SV431USB with a rugged and durable body that adds to the unit's reliability and dependability. The SV431USB is a true cross platform USB KVM that ensures a smooth and reliable operating experience. This integrated KVM switch also functions as an USB hub allowing the selected computer to have access to up to 4 USB devices. The SV431USB works with any operating system that supports the USB human interface device specification.
Note: This product will function as a standard KVM switch, powered by USB only. If you wish to use the integrated USB hub with high powered devices such as scanners, USB mass storage devices, or Multimedia Keyboards, the optional power adapter may be required.
Tech specs Feature Description Manufacturer Warranty Service & Support 3 years warranty Service & Support Details Limited warranty - parts and labor - 3 years - carry-in Expansion / Connectivity Interfaces 4 x USB - 4 pin USB Type B male - 4 ¦ 4 x display / video - VGA - 15 pin HD D-Sub (HD-15) male - 4 Connections 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) male - 1 ¦ 2 x USB - 4 pin USB Type A female - 2 Networking Ports Qty 4 Data Link Protocol USB Connectivity Technology Wired Status Indicators Port status, power Miscellaneous Rack Mounting Kit Optional General Device Type KVM switch Enclosure Type External - 1U Width 8.7 in Depth 5.1 in Height 1.7 in Weight 2 lbs Enclosure Color Black KVM Keyboard / Mouse Interface USB KVM Local Users Qty 1 local user Max Resolution 1920 x 1440
Feb 18, 2009 | StarTech.com StarView SV431USB 4-port KVM...
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid mixer is leaking from the part that spins?
I took mine apart and all the grease had settled down around the shaft in the housing due to lack of use,found no seal.Going to spread grease back up on gears,see what happens.I found this at KitcheAids web site.Good luck.
Dec 01, 2008 | Food Mixers
KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
