Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
My blower starts after primed and cranked but only runs for about 5 mins than wont start after that until hours later. what can possibly wrong?
I have the same problem. Much appreciated if anyone can offer a solution. Thanks!
Posted on Jan 12, 2011
WHEN LEFT FOR AN HOUR MY 2010 SPRINTER TAKES A LOT OF CRANKING BEFORE IT STARTS. WHEN IT HAS BEEN RUNNING THERES NO PROBLEM UNTIL I LEAVE IT FOR AN HOUR IT WONT START AGAIN SOMENE SAID IT COULD BE THE FUEL...
I've had the same problem with my truck. It's not unusual for one to have to re-prime the fuel pump. just turn the key on, let it sit for a second, and when you no longer hear the fuel pump priming fuel (sounds like a whining noise before you start the engine), crank it up.
Sep 16, 2013 | 2010 Mercedes-Benz Sprinter
Leaf Blower starts and runs for about 5 minutes. It stops and will not start until engine cools. Plug has been replaced and carb cleaned. Thanks for your help
Remove the airbox cover and air filter. Run unit until it dies then immediately spray a shot of carb cleaner into the carb and attempt to start. If it tries to start or starts then you have a fuel problem ( stiff diaghram in carb or clogged screen in carb). If it wont start or pop on a prime then the ignition module is failing and will need to be replaced.
Oct 07, 2012 | Poulan Garden
Saturn starting promblem.
Had same problem with 6cyl. merc.
Started fine cold but wouldn't start when turned off hot.
Replaced spark plugs & worn dist. cap .Problem solved.
Feb 23, 2012 | Cars & Trucks
My car starts up then runs for ten mins then dies. it will start up after that but wont stay running. then i come back an hour later then she starts right up and drives for ten mins then back to the same...
sounds like a bad cam sensor. have scanned if light on dash is on. if no scanner any auto parts store will scan for free. a bad or failing crank sensor will make vehicle stall out after a few seconds or minutes. if it is bad enough it will not start. because it controls timing.
Aug 19, 2010 | 1990 Mercury Topaz
I have a 2001 saturn sc1 that is having intermittent starting problems. At times after its been driven ill go out to leave again and it won't start. No clicking when I try and start it either. Wait for...
I am having the same problem. did you figure out what was wrong with yours. I have tested all of the wires in the harness under the dash, they r fine. I pulled off the starter and had it tested; O'rilies said it was fine. It is a 5 speed, and I can push start the car just fine any time. Like yours, some days my car starts, some days it doesn't. The days it starts, it runs fine with no problems starting or running. the problem is the days that it wont start.
Feb 25, 2010 | 2001 Saturn S-Series
First started not cranking after shutting off say to fill up, mite wait 5 min or a few hours and it will crank and be fine for weeks. now it started like losing power and going dead. agan may wait 5 min or...
Might be two problems, but one is your igniter in the distributor. The second, the idling problem is either your throttle position sensor, or a vacuum leak. With the engine running , check all hoses for leaks by wiggling them around, while listening for a hissing. Check intake bolts for tightness.
Feb 01, 2010 | 1992 Honda Accord
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
140 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
